how to create a Torodial Helix on a Pretzel
tsachi_davidov
Member Posts: 13 ✭
Hello everyone
I have this pretzel shape and I need to cut the outer surface of it into a coil shape so that I can wind a flat copper wire 5mm wide and 0.25mm thick
Total 22 windings required
I can't find a way to make this coil and cut the pretzel to complete the task
Thank you very much for the full tutorial/assistance
Tsachi
Check out the "3D spiral" featurescript, I think it might do exactly what you want…
https://cad.onshape.com/documents/59007ff281e43510ea3797a2/v/a32c98e33ad3fdfd68973e79/e/373bf12ed1df148a9df613b0
@MDesign and @eric_pesty are correct. You can use a combination of custom features to do this quickly.
To see how it was made, double click the features in the tree. It will let you open each feature and see what was selected and which values were used.
https://cad.onshape.com/documents/047024f94b7661a7865160f7/w/2d709c468dc4354cd42caec0/e/c54271b873d4b8ebce01c…
To add custom features that you don't have to your toolbar, just right click the feature in the tree, then open linked document.
From there click the Custom features button, then click the features that you want from that document.
Hey
I could not find the exact guidance to my question, I'll appreciate more accurate reply thanks in advance
Hi Eric
Much appreciated, however I have no idea how to use the script
Can you guide?
Ps I'm opening now from my mobile and see a code...
hi Eric
thank you for your feedback however i do not understand in script and code :)
any other way to do it easily / full guidance how to place the script inside the onshape?
hi Michael
i found the next solution you posted to MDesign and modified it to reach my rerquired shape:
https://cad.onshape.com/documents/c16e6ade60b00d1f4a39a4c4/w/c399c7481ff7a32461770d3e/e/1733ffe736fc1c3aeb349c90
i think it is solving my issue now, however i still want to leatn best way to do it easily
also i do not understand why it is so simple to add Helix to a Cylinder and not to Pretzels… :)
thank you all to any feedback!
Tsachi
Thanks Alex
what i need is the attached photo which i generated from your design file and changed some data:
thank you all!
Tsachi
There was also this one I wrote a while back for exactly this shape from this thread.
https://cad.onshape.com/documents/49d65188db8609de89a767d2/w/d3de9c007e566ad7341690a8/e/31f8a28c0d8abed5daad087d
