Spline constraints
I'm looking to constrain splines within a drawing. I can't work out how to constrain the direction/length of the spline handle... Any tips?
Also, it appears that there are no spline handles for points except for the start and end points. Is that really true? How do I manipulate the length/angle of a curve within the spline? Surely this can't be the case otherwise it seems to me that splines are severely limited in comparison to other cad packages.
Al thoughts and (I hope) solutions gratefully received!
NeilCooke Moderator, Onshape Employees Posts: 5,889
Hi @Edward_12
In a sketch, you can constrain a spline handle using dimensions or constraints (between the endpoint of the spline and the endpoint of the handle).
There are no handles on spline points at this time (please raise an improvement request). Mathematically a spline with handles on inner points is actually two splines end to end, so you can do the same thing in Onshape, it's just not as quick.
Hope that helps.
Senior Director, Technical Services, EMEA13
Hope that helps.
Good to know. Getting to using splines more in a model and this fits the bill. TY Neil.
