CNC Export
GWS50
Member Posts: 500 PRO
I am still trying to find a way of exporting a file for CNC cutting. Unfortunately Onshape only exports one face at a time so if there a a recess it won't export as one file. This means extra work piecing together the individual files so I can cut them as one part.
Can anyone help with this or does anyone know if this will be dealt with in future updates.
Many thanks
Many thanks
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
I am assuming you are using these for 2.5d programming ie. getting the basic form of the part with profiles positioned at different depth's on the z axis.
Could be a good feature request to be added to the dwg/dxf face export.5
i guess you are exporting in dxf format, since this seems to be the industry standard. My guess would be that you can export all the lines you want if you insert the part into a drawing and then export the drawing.
I'll try the project method but would be great if it could be an option as part of the DXF export.
Many thanks all for the help
