Improvements to Onshape - April 4th, 2025
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
edited April 25 in New in Onshape
We are back with another big update. This update includes exciting new technology, and a long list of highly-requested new features. Let's dive in.
ONSHAPE AI ADVISOR (BETA)
The Onshape AI Advisor is an AI-powered Onshape expert created using Onshape's large library of learning materials. It is available to everyone in the Onshape Learning Center
https://onshape.wistia.com/medias/krhcwmdb1s
CAD IMPROVEMENTS
SKETCH CONSTRAINT MANAGER
The new sketch constraint manager provides a detailed, filterable list of all sketch constraints that highlights conflicts and external references. Delete any of the sketch’s dimensions, constraints, and entities from this list.
https://onshape.wistia.com/medias/ox6vyy79p3/embedType=web_component&seo=true&videoWidth=960
WINDOW BOX DESELECT
A crossing window can now be used to deselect geometry by using the CTRL key.
https://onshape.wistia.com/medias/d6zbisd6fb/embedType=web_component&seo=true&videoWidth=960
KEYBOARD SHORTCUT IMPROVEMENTS
Keyboard shortcuts can be assigned to Collapse all in list and Expand all in list.
DRAWINGS IMPROVEMENTS
PROJECTED VIEWS AND SECTION VIEWS ON VIEWS WITH BREAKS
When creating a projected view or a section view from another view with breaks, the view inherits the same break definition.  Section views can also be created directly from a view with breaks.
https://onshape.wistia.com/medias/ncmenguprl/embedType=web_component&seo=true&videoWidth=960
AUTOMATIC CENTERMARKS FOR PARTS WITH LINEAR PATTERNS
Parts that contain linear patterns now provide automatic centermarks and centerlines upon view insertion.
CUSTOM DATUM TARGET AREA
Datum target symbols can now be created using a custom sketched-in shape or area region of your model.
DATUM ATTACHMENT TO WIDTH DIMENSIONS
Datum symbols can be attached directly to a dimension value for a width, adding it to the extension line, ensuring datum symbols move in-line with the dimension.
ENTERPRISE IMPROVEMENTS
RELEASE AUDIT DASHBOARD IMPROVEMENTS
Release notes and the names of approvers from Release Candidates now appear in the Release Audit dashboard.
RENDER STUDIO IMPROVEMENTS
MATCH SCENE PROPERTIES
Match all scene properties of the current Render Studio tab with those of another Render Studio tab. These include settings from the Scene panel, Environment panel, and Named views.
https://onshape.wistia.com/medias/c7cuyl7atb/embedType=web_component&seo=true&videoWidth=960
PERSISTENCE OF RENDER OPTION SETTINGS
Render option settings are remembered from the latest render. Settings are retained after the page is refreshed and after logging out and back in. These settings are tab specific.
CAM STUDIO IMPROVEMENTS
TOOL LIBRARY UNITS
When creating or editing a tool, an option exists for a separate unit (Inch or Millimeters) for each cutter, holder, and arbor beyond the Document Workspace units. The unit will also be saved to the library.
https://onshape.wistia.com/medias/bnttlto7to/embedType=web_component&seo=true&videoWidth=960
LEARNING CENTER IMPROVEMENTS
MULTI-PART PART STUDIO COURSE IMPROVEMENTS
The Multi-Part Part Studios course has been completely redone. It includes brand-new videos and exercises to help users design more effectively.
«1
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    Great update! I'm looking forward to testing the new CONSTRAINT MANAGER and am curious to see how helpful the new AI Advisor will be in real use. Thanks Onshape team!
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 451 PRO
    Devastating series of version names. My first party conic dreams were almost realized.
  • paolo_ciancipaolo_cianci Member Posts: 24 PRO
    FINALY section views on views with breaks!!👍
  • Caden_ArmstrongCaden_Armstrong Member Posts: 348 PRO
    The new "Developer" tab in enterprise settings - does this ensure that an application is owned by the enterprise and not an individual user?
    Is this going to be coming to professional as well?
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • aeromorrisonaeromorrison Member Posts: 74 PRO
    Sketch Constraint Manager…Yes!
    The application is owned by the Enterprise/company and can only be used in the context of the Enterprise.
    Jake Ramsley
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 224 image
    Support & QA
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,474 PRO
    Curious to try the sketch constraint manager and see what it does!
    Match scene and persistent render settings was definitely needed, glad to see these!
  • MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
    Especially excited for this AI integration. For others interested, don't forget to vote on this improvement request so that this tool will be useful for FeatureScript and App development:  AI Advisor (Wider Data Range) - Improvement Request
    Been looking forward to having a constraint manager for some time now! This looks awesome!
    Render studio and quality of life improvements are always fantastic.
    Thanks OS Team! We appreciate your hard work in keeping Onshape sharp 😎
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 119 PRO
    SOOO many goodies here! Actual Gods. love this:
    -Constraint manager
    -AI learning tool
    -Seciton Broken views
    -Window box deselect (Hopefully this works while making exploded views)
    -Cam studio units will be nice once they add homag machines for me to use
    Question, what is "Expand all in list"?
  • michael_zeaglermichael_zeagler Member Posts: 146 ✭✭✭
    I stared at the screen like it was hypnotoad watching the constraint manager. If it had existed 15 years ago when I started using Solidworks I would probably have had a year's worth of time freed up.
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Very good , thank you :)
    Looking forward to use the Constraint manager.
    This is an awesome set of updates! I'm looking forward to using the new constraint manager. I'm also glad to see Onshape using AI tools; I will definitely try this out.
    Just wondering when we will see the 2d profile cutting in CAM?
  • gonzalo_chomongonzalo_chomon OS Professional Posts: 56 ✭✭
    Constrains manager Woooooiiiii 😀
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    Amazing. Constraint manager is brilliant.
    Are there any estimates for CAD dealing with 2D cutting? (Nesting, multi sheet workspace, etc.)
    Crucial long term decisions are based on this….
  • MDesignMDesign Member Posts: 1,265 PRO
    Voted most underrated update… window UN-selection.
    Constraints manager should be super helpful for diagnosing forum questions 👊
  • scott_lakescott_lake Member Posts: 8 ✭✭
    Sure wish there was a select toggle so that users could turn off multi-select on every dang thing as a preference item. This is one of the most frustrating things about Onshape coming from any other 3D CAD platform, including Solidworks.
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 50 image
    Expand/Collapse all allows you to open/close all folders in a Part studio Features list or Assembly Instances list. Feature was added last release, shortcut added in this one!
    https://forum.onshape.com/discussion/27130/improvements-to-onshape-march-13th-2025/p1#:~:text=EXPAND/COLLAPSE%20ALL%20FEATURE%20FOLDERS
    Yeah, I am also wondering about 2d CAM and nesting.
  • SebastianMaklarySebastianMaklary Member Posts: 15 PRO
    Datums on width dimensions is such a big help. It has been haunting me to manually align the datums.
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 197 image
    Join me today at 12pm noon Eastern US time for community reactions to the latest update with live demos and deeper dives:
    https://www.linkedin.com/events/7314016890773803009/comments/
    https://www.youtube.com/watch?v=qTCaUAj8aAk
    Regards,
    Mike LaFleche   @mlaflecheCAD
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    Awesome! A constraints manager.
    I'm defiantly excited to try that out! I got so used to doing it the hard way all these years, I didn't know something like this was possible.
    This should help hunt down those accidental constraints that woke themselves up during placement.
    Nicely done
  • joseph_lavinjoseph_lavin Member Posts: 7 EDU
    i'm curious as to how some one could be an Onshape pro and how to become one.
    edited April 7
    @joseph_lavin The "PRO" category tag beside our names is from the "Professional" subscription: https://www.onshape.com/en/pricing
    You also get this if you are Enterprise and or Partner level with Onshape I believe.
    The quickest way to actually become a "pro" at Onshape, is to complete the Learning Pathways.
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    If you mean the "PRO" icon just beside the username, just pay 2500$US per year and there you are! 😉
    If you want to become pro at using Onshape, just practice for a few years and you should get closer to your goal…
    Encore une fois, d'excellentes améliorations! 👏
    Pour les francophones, AI Advisor communique en français, essayez-le!
    Great improvements again Onshape! 👏
    Would be great if AI Advisor could remember requests history per user.
