Help with Complex "Fillet"
nolan_van_dinenolan_van_dine Member Posts: 4
Hi there,
I'm wondering if anyone can offer suggestions on how to create a "fillet" between the edge of the slanted section and the top of the ring but tangent to the horizontal radial edge as shown in blue but flush and with two squared edges
Screenshot 2025-04-06 221226.png Screenshot 2025-04-06 221244.png Screenshot 2025-04-06 221258.png
  • jelte_steur814jelte_steur814 Member Posts: 454 PRO
    edited April 7
    do you mean like this:
  • nolan_van_dinenolan_van_dine Member Posts: 4
    I don't think so but its hard to tell, that looks like the regular fillet tool which creates a curve along the entire radial face.
    I'm looking to keep the selected face flat
  • _anton_anton Member, Onshape Employees Posts: 438
    Depends on what exactly you're asking of this fillet. Easiest solution is to take the fillet exactly to the bottom of the lid, thusly: https://cad.onshape.com/documents/f62756ba36438dddd7c73f9a/w/b120076dd65dbe57887c613e/e/3f0049b6328a3395f8c24dd9
    Using width fillet is another option: https://cad.onshape.com/documents/f62756ba36438dddd7c73f9a/w/b120076dd65dbe57887c613e/e/fdf38b0bf83b33c2353886d8
  • MDesignMDesign Member Posts: 802 ✭✭✭
    Like this?
  • S1monS1mon Member Posts: 3,298 PRO
    I would probably use a couple of bridging curves and a boundary surface. Then you could make a small chamfer or fillet, and replace that face.
  • EvanReeseEvanReese Member, Mentor Posts: 2,362 ✭✭✭✭✭
    throwing my hat in the ring. This solution is very flexible.https://cad.onshape.com/documents/9a6ca0c6773ba398f1268908/w/c8c32e3b908a8b65897c32dd/e/87810b113552842643c13476
    variable fillet is probably what your looking for.
