a suggestion about the color of dimension lines
when a sketch is constrainted totally, the color of all the entities is black . but sometimes when giving many dimensions to a complex sketch,due to the same color for the constraited entities and dimension lines, it is not easy to distinguish if a line is constrainted or not from visual sense if many dimension lines passby this line ,so I want to suggest that if the color of dimension lines can be changed ?
5
Is there IR up for voting?
Good point @shanshan
