Configuration Variables and Tables
Hi,
I have a simple part that is a custom connector. I have two configuration variables that define the size of the two connecting ends (e.g., 6 mm to 4 mm). The size of the part changes with these values.
Is there a way to have a table in a drawing that shows values for a dimension for different combinations of these two configuration variables?
Thank you!
So the answer appears to be no, at least for now.
Thank you!
