Improvements to Onshape - April 25th, 2025
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
edited May 2025 in New in Onshape
While we may be focused on stability and performance for this release and the next, we still have some exciting improvements to show you. When you are done here, make sure to check out the changelog to see what else we have been working on. Let's get started.
CAD IMPROVEMENTS
REPAIR MANAGER IMPROVEMENTS
Improvements have been made to Repair Manager that allow you to forward propagate some references. The new Replace reference option allows you to replace a broken reference in the current feature, and propagate that replaced reference downstream to any features that use that reference.
https://onshape.wistia.com/medias/a4vn5aof8w
SHORTCUT KEY IMPROVEMENTS
You can now add Section view, Mass and section properties, and Measure and section properties to your shortcut toolbar. This gives you quick access to some of Onshape's most popular features.
https://onshape.wistia.com/medias/jc08y15vbi
RENDER STUDIO IMPROVEMENTS
SCENE LIST IMPROVEMENTS
You will find new, more advanced, Scene list filters in Render Studio. These filters include the ability to filter by criteria like appearance and decals. This allows you to quickly filter the scene list. You will also find the scene list has been split and now has two panes. The top pane contains the scene geometry, as well as Transforms and Projectors, while the bottom pane contains Appearances.
https://onshape.wistia.com/medias/hq1kiprm3c
RESET APPEARANCE ON FACES
If faces have an appearance set in the Part Studio, and their appearance is changed in Render Studio, they can now be reset to the original Part Studio appearance via the Scene list or graphics area context menu.
FOCAL LENGTH FIELD OF VIEW
You can now define Field of view by focal length. In the past, this was limited to angle.
LEARNING CENTER IMPROVEMENTS
NEW LOCALIZED TRAINING
You will find two new localized offerings available in the learning center. The Onshape Hands-on Test Drive is now offered with Japanese subtitles and text and Onshape Bootcamp is offered with Traditional Chinese subtitles and text.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 302 PRO
    Focal Length Control,🤓 yeih!
    CAD Engineering Manager
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,529 PRO
    Render studio split will definitely big for retaining sanity when setting up a appearances!
    Replace reference could be huge in some cases (assuming it works for "bodies")! Also hopefully coming to sketch entities soon?
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 121 PRO
    Loving all the little quality of life feature changes and fixes!
    Looking forward to even better performance!
    Is there any areas specifically that we will most likely notice significant improvement?
  • aeromorrisonaeromorrison Member Posts: 77 PRO
    Solid release. I like the direction repair manager is heading.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
    Propagating reference update is really nice and should speed repairs.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,035 PRO
    Forward Propagate looks promising
  • kees_bijkerkees_bijker Member Posts: 171 ✭✭
    Repair manager sounds like I needed that like a year ago, that is super cool.
    Will have to experiment with that for sure. Thanks for a solid improvement.
  • EvanReeseEvanReese Member, Mentor Posts: 2,789 PRO
    Replace references with propagate is awesome!
  • BanhammerFromPhightingBanhammerFromPhighting Member Posts: 2
    it update cool
  • Mansur_ZagitovMansur_Zagitov Member Posts: 2
    Where can I find the field of view settings?
  • Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 227 image
    Those are for Render Studio only and are under the view cube menu there.
    edited April 2025
    Just realized this, I thought it was for Perspective View 🙃
  • christian_pettychristian_petty Member Posts: 82 PRO
    I really missed the Ref Manager from Creo. Glad to see this here!
    Christian Petty - Mech. Design Engineer, Radian R&D
  • Eric_WongEric_Wong Member Posts: 24 PRO
    Great update, let's get to the point where we can forward propagate everything!
    Look not sure if it's just placebo effect but I'm deffinitally noticing a significant boost in processing speed while working. Loving the snappy feel
