Sketch - pattern a spline
jerome_goyet
Member Posts: 16 ✭✭
Hello,
does any one able to pattern a spline (linear or circular pattern) on a sketch ? all geometries work fine but the spline.
Any hints ?
Tks in advance
Jérôme
Any hints ?
Tks in advance
Jérôme
2
Currently you can use work-around by making that spline to solid or surface then perform pattern operation by selecting spline part or surface and join them with the help of Boolean operation available in pattern.
Am I missing something?
You can help us prioritize this by voting on the associated Improvement Request:
https://forum.onshape.com/discussion/7925/circular-pattern-a-spline
In the meantime, can you make a solid or surface and use a Pattern feature rather than a sketch pattern?
Almost ten years later. I still can't pattern a spline. 😂
To be clear: ten years after this issue was raised, you want the users to continue filing tickets requesting a "feature" which is so utterly basic that its exclusion universally registers as, "I found a bug".
To be clear.. You signed up just to say that?
