Up to Surface in Extrude
Patrick_Wolber
OS Professional Posts: 4 PRO
I don't see an "Up to Surface" command in Extrude. Was this deleted? Is there a new way to do this?
UX/PD/Community Support
Re our terminology discussion on the other thread
https://forum.onshape.com/discussion/1850/is-there-a-split-face-feature-that-would-extend-all-the-connected-faces#latest :
@abefeldman 's reply seems to suggest the folk at Onshape have adopted the same convention as SW: a "Face" belongs to a solid body, whereas a "Surface" does not
@abefeldman: I wonder if "Up to body" would better convey what is currently meant by "Up to part"?
It is not at all obvious that a surface qualifies as a part, and I'm not sure that it's desirable to create that precedent.
No memorizing, no guessing
I personally think @3dcad makes a valid point in this connection, on this occasion.
It sometimes happens, when pursuing simplicity, that the appearance of simplicity is allowed to take precedence over actual, or overall, simplicity.
We have seen this, I think, with the feature list, which borders on being impoverished (because of the info it fails to communicate) rather than simple.
