Improvements to Onshape - May 16th, 2025
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
edited June 6 in New in Onshape
This is the second of two releases to focus on stability and performance, but we have still managed to find the time to throw in some super cool and highly requested new features.
VISUALIZATION
ISOLATE AND MAKE TRANSPARENT
The Isolate and Make transparent tools now include a slider to adjust transparency. An option to select transparent geometry enables both tools to be used effectively when interacting with both transparent and opaque geometry.
https://onshape.wistia.com/medias/61fvertep9?embedType=web_component&seo=true&videoWidth=960
PART STUDIOS
REPLACE FACE
The Replace face feature now accepts more than one face as a replacement, enabling more complex results with a single feature.
https://onshape.wistia.com/medias/8ey89qru42?embedType=web_component&seo=true&videoWidth=960
PUBLICATIONS
INSERT RELEASED PARTS
Released parts can now be added individually to a Publication. This removes any other parts in the Part Studio, reduces clutter and ambiguity, and protects intellectual property.
https://onshape.wistia.com/medias/8jcpxqvzc2?embedType=web_component&seo=true&videoWidth=960
GENERAL
RESUME LAST LOCATION
After a period of inactivity, the current Onshape session may be signed out. Signing back in will resume the last session, either opening the last active Document, navigating to the last open folder, or showing the last search results.
https://onshape.wistia.com/medias/gtlq5b2sul?embedType=web_component&seo=true&videoWidth=960
SORT FOLDERS IN "MOVE TO..." DIALOG
When moving Documents, Publications and Folders using the "Move to..." context menu, the list of Projects and Folders can now be sorted alphabetically or by Last modified for easier navigation.
ONSHAPE VISION
CONNECT MULTIPLE DOCUMENT TABS
Multiple Onshape Document tabs can now be shared from the Onshape mobile app on an iOS device to the Onshape Vision app on Apple Vision Pro. After a Document is shared, return to the Documents page and all shared Documents will be listed in the dialog as shown below. The Document will still be viewable in Onshape Vision even though it has been closed on Onshape mobile. Open one or more further Documents and share with the Onshape Vision app. All Documents will be shown and available to view on the Onshape Vision Documents page.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 279 PRO
    "Enterprise: Improve SSO experience for existing users already have an Onshape account"
    Does this mean I won't get locked out of my Onshape when I get added to other enterprises?
    Great seeing a changelog with that many "fixed an issue" items.
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • S1monS1mon Member Posts: 3,329 PRO
    Yes, these are still some very nice to have improvements on top of the stability stuff.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
    edited May 16
    Sorry Caden, but this has nothing to do with "Disable sign in" on SSO. You'll still get locked out. This is when a user has a free account and they are added to an Enterprise. Our authentication email and workflow was a little confusing.
  • aeromorrisonaeromorrison Member Posts: 59 PRO
    Great release. I really like seeing some focus on publications.
  • romeograhamromeograham Member, csevp Posts: 706 PRO
    edited May 16
    Nice Work Onshape team!
  • albjerrealbjerre Member Posts: 24 ✭✭✭
    The updated "Replace Face" feature is a nice update!
  • Michael_HillMichael_Hill Member, pcbaevp Posts: 4 PRO
    I do like the "ISOLATE AND MAKE TRANSPARENT" addition. I think this will save my team a lot of time!
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 116 PRO
    These are some tasty improvements!! The new Replace Face functionality is going to make adjusting floor levels that much easier!
  • martin_kopplowmartin_kopplow Member Posts: 796 PRO
    Replace with more than one face! Yeah! :0)
  • kees_bijkerkees_bijker Member Posts: 151 ✭✭
    Holding down the "option" key on Mac or the "alt" key on windows………what about Linux? Should I follow the windows because I do not have an "option" key?
    I like the look of this and will experiment to see how it works. Often the section feature is needed to assemble things so this could be easier.
    Nice work as always.
  • robert_johnstonrobert_johnston Member Posts: 49 PRO
    Nice nice, looking forward to next release with new features. Hopefully some of the background stuff allows the sheet metal loft to progress and get released.
    Can we also get the SORT FOLDERS IN "MOVE TO..." DIALOG. treatment applied to the "Insert Parts and Assemblies" window, make window size adjustable and be able to sort list?
  • jelte_steur814jelte_steur814 Member Posts: 472 PRO
    Very happy with the replace face improvement as well!
  • smit_patil773smit_patil773 Member Posts: 2
    @kees_bijker Yes, it's alt key on Linux.
    Thanks, it was the most logical tbh. Good to know
    I love the replace face tool and probably overuse it. The multi-face feature adds more use cases, which will come in handy.
  • J_CalJ_Cal Member Posts: 3
    I agree with
    robert_johnston
    Would be great to be able to sort alphabetical when inserting parts into assemblies.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 450 PRO
    I really like all the fixes in the changelog. Especially this one:
    • Fixed an issue with export to PDF gives incorrect shaded view for transparent parts
    Thanks for the good work!
  • GWS50GWS50 Member Posts: 452 PRO
    ooooh yes, I've just come across this. Saves me having to export Screengrabs
  • partsovenpartsoven Member Posts: 29 PRO
    Onshape FTW
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 67 PRO
    Wait a minute, I just realized that the new replace face function enables lofted sheet metal by letting me replace lofted spline faces with "extrude" faces. That'll come in handy.
    Even more impressive with cones
    What?? Friday already?
    So, if we've had a couple rounds of stability fixes behind the scenes, does this mean we get special treats today?
  • EvanReeseEvanReese Member, Mentor Posts: 2,399 ✭✭✭✭✭
    I see a version name commit for assembly mirror. They're coming for me lol
