Cut List (New Custom Feature!)
MichaelPascoe
Member Posts: 2,743 PRO
Cut List
https://cad.onshape.com/documents/395304920b30c3b382fd312d/w/86481637ad1e9da01b0e5d60/e/e19230df69a29e1fc2259b9d
How to find custom features:
- Click the "Add custom features" button in your toolbar, you may have to search for this in the search tools box
- Select "Public"
- Show advanced search options
- Select "feature studio"
- Search for the title of the feature you are looking for
4
I've been sharing this method so that people know there is a way to look for other features out there. Often, I don't know exactly what I'm looking for, just a general idea.
Update!
Update!
Measure cut list - Custom featureNote: you can still switch back to manual measurements by clicking the entry from the list in the feature.
Update!
This in turn improves performance by skipping duplicate parts.
The feature will recognize the duplicates and not spend time measuring them.
Thank you so much buddy. With a personal note.... Really appreciate this.
Update!
This is noticeable when there are things like holes or labels cut into the faces which change the geometry but not material cut size.
hi Pascoe,
I have been using this cutlist tool for a while now and want to tell you how thankfull I am. i didnt realize all the updates until just now and wow what a great tool this is. thanks alot for this.
Sure thing! @joris_splinter Glad it is helping you out 😎
Michael, this is an impressive feature script, I really appreciate that it automates the data entry, it saves so much time.
Would it be possible to have an option for fractional inch measuerments in the table?
And, is it possible to use the callout (balloon) with the custom table? Seems like I'm missing something simple.
Thanks for the feedback @tyler_smith171.
Update!
Thanks @tyler_smith171 for your input. These are some useful changes.
Wow! Thank you!
Good morning! Sorry if this shows up twice—my first post hasn't appeared for me so I don't know if it got moderated or my adblocker ate it, so trying again.
Questions about this feature:
Edit to note #2 is a rounding error. If I set the precision to 0.0001 to pick up the sixteenths, it works. I don't know how FeatureScript works, but I'd expect conversions to be done with numbers before they get rounded for display.
Further edit, it doesn't matter what my preferences are for precision—Measure Cutlist will use 0.001 unless I manually change it.
Link to project.
And thank you again for this feature!
Additional question/feature request: can material be included in the table?
Hey @joe_fisher391, glad you like it! 😎 These ideas were simple yet important enough that I went ahead and pushed an update to support some new functionality. As far as the rounding goes, try changing the Round table values to 0.0625 in. This will help ensure you don't get 80/256.
Update!
This worked exactly as I'd hoped, thank you so much for that extraordinarily prompt response!
Also, I'm using the prefix field for my materials. It's a little extra work, but not too terrible.
If you don't mind a little more feedback, I'm having an unexpected issue. I've got 4 parts here, which all happen to be the same size. If I select any one, two, or three of them, it works as expected. If I select all four, it only counts 3!
I did a little testing, and v35 does not show the issue, but v36 and up do.
There must be something wrong with the additional duplicate check logic in one of the previous updates. I'll have a look when I have the time.
Hi Michael,
I have tried all sorts of things but is there a way to add another column. I may be being stupid but I would like 6 (One for Materials)
Many thanks for your time. The script is certainly is a game changer, thank you.
I see from you code that you are working on adding a Material column. You're awesome!
Would it be difficult to make the bounding box dimensions apply to the flat sheet metal instead of the bent state?
Thanks!
Eric P
@poulsone Yes, I was going to make a quick edit and give everyone a surprise update. Unfortunately it is taking a bit more time. I wrote this feature a long time ago and can see how much my coding has improved since then. lol this is painful!
@joe_fisher391, @simon_norris040, and @poulsone. See the latest update. I think your requests will be a valuable edition to the feature and I was able to set aside a small amount of time to add them. Joe, I wasn't able to fix the part counting bug in a reasonable amount of time so I included the option "Measure duplicate parts" which will force the feature to measure each part, bypassing the counting bug that occasionally happens on some types of parts. Really the feature needs a re-write, but I don't have the time. Enjoy the update! =)
Remember, we do this for a living at CADSharp. So if you need some real automation for your daily work, don't hesitate to contact me.
Update!
Update!
Thanks so much for your quick response. Great feature added!!
Hey this is amazing, super helpful. I may have missed something, but is there a way to use the callout feature in drawings to auto populate to the part Id in the measure cut list? My ultimate goal is to use the named parts to indicate which part is which in the part studio drawing.
@Paul_Reamey you can set the part's description to match the table row id's. Then use the callout to get the part's description.
@MichaelPascoe you're a life saver! 🫶
Is there a way to export the cut list to CSV?
