Import woes
Hi All,
I have been trying to import a model of an R1 engine from GrabCad, i can open it and spin it round etc, but when i try to add it to an assembly it only picks up some of the random parts that make up the assembly, I've tried importing it as a flattened assembly but it still wont work.
Please help
Regards
Bart
Please help
Regards
Bart
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
You could use the thicken command to turn surfaces into parts5
Yes it does have surfaces unfortunately... i had the same with a bucket seat i was trying to use too. do you know of a fix for this?
Maybe you can convert the surfaces, or re-draw them somehow.
Any help would be gratefully received.
Regards
Bart
Some recent discussion on this forum on this topic -
here's one which might help
https://forum.onshape.com/discussion/1787/i-have-an-stp-file-that-i-imported-many-surfaces-zero-parts-this-prevents-making-drawings-no
If you have problems, it may be necessary to offset adjacent faces towards each other. MCAD modellers like Onshape do not tolerate "zero thickness geometry"
(in this context, geometry seems to mean "solid body")
