Tutorial - How to create raised text on a curved surface
david_gross
Member Posts: 10 ✭✭
This tutorial is for creating raised lettering/sketches on a curved surface. The surface can be a cylinder, sphere, cone, dome or any other non-plane configuration. I hope you will find this useful!
1. Choose a sketch plane from which you want to project the lettering. This can be one of the three native planes or a user-created plane. Note that there is a front and a back side to a plane, where lettering will appear normal on the front side and in reverse on the back side. This applies to both native planes and user-created planes. You can tell which side you are on by the direction of the plane name (for native planes) or by sketching text on the plane. If you want to project from the front side, then the lettering will appear normal, but if you want to project lettering from the back side, you will need to create a reverse-direction plane.
2. To create a reverse-direction plane, first make sure you have an existing sketch line coincident with the new plane or create a new sketch to draw one. Click the Plane icon to create a new plane and select type Line Angle in dropdown. Select the desired sketch line and enter 0 degrees for the angle. Now create a new sketch on this plane and insert some text. If it is in the proper direction, you can proceed. If not, go back and edit the plane and enter angle of 180 degrees to flip it. The text should now be in the proper direction. I have not discovered any rule to know which direction a plane will be when created so it is easiest just to start with 0 degrees and sketch on the plane to find the orientation. You can also tell by the orientation of the sketch label which appears on the sketch plane when in sketch mode.
3. Now place the text that you want to project on the desired plane. I have placed the text on a plane behind the surface to be projected on but you could also create the sketch plane in front of the surface. The “text” does not need to be just text but can be any closed sketch or sketches like a logo, shape or spline as I have done for the word “Wizard”.
4. Now you will need to create a new surface (not a solid) which is offset from the surface where the text will be by the height of the text. Otherwise the text will just project to the surface and be invisible. Here I have created another domed surface offset by 1 mm.
6. In the Extrude dialog box, click the box for ‘Second end position’, choose option ‘Up to face’ and select the desired face where you want the text to start as the criteria. This will be the minimum extrusion distance from the sketch plane. Here I have chosen the front surface of the hub. Now hide the offset surface and you should have text that is raised above the surface by the offset distance.
7. The above steps are for a sketch plane behind the surface that you want the text to extrude from. If the sketch plane is in front of the surface, just reverse the faces in the Extrude tool so that the first end position is the part face that the text is on and the second end position is the offset surface. It helps to remember these as maximum extrude distance for first end position and minimum extrude distance for second as above. This is shown in the picture below.
8. Note that you can also select the New option rather than Add for the extrusion, which will create a new part for each letter or closed sketch portion. This can create a lot of new parts so it is best to just select Add for the extrusion so it will merge with the existing solid. An exception is if you want to change the appearance of the text such as color, in which case it needs to be created as new part(s).
That's it! Please comment if you have any tips/suggestions/improvements for doing this. Happy texting!
The tip for creating a reverse plane is particularly handy, until such time as Onshape implement a "flip plane" control.
Muchos kudos, and thanks VERY much!
https://cad.onshape.com/documents/3bef141eee714b75930079d0/w/64bdc8d4dabb4f7e84de4419/e/3425b177aef3445fb4dd0581
Also, a link to where I used it, just for fun (warning - big file!):
https://cad.onshape.com/documents/1d04849d34a046c68e704fd2/w/57679519584c4f9da1a4ed89/e/7bf831286d1046a0b8b83e4c
When you created the offset it created a new surface.
You cannot hide it from the Offset Surface entity.
@david_gross Great tutorial! Very helpful.
