Cantilever clamp vid turorial, stuck!
Hello everyone,
I'm stuck on the cantilever clamp tutorial at 1:23.
Here is the link to my document (public viewing)
I can't seem to extrude the smaller cantilever arm. You can see where the red arrow is, it won't let me form a solid shape. What am I doing wrong that it won't let me extrude it?
THank you in advance!
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
If you hover over the red "Extrude 1" title of the edit dialog, it should tell you why it is failing. Maybe there is a tiny gap in your sketch? There are a number of possibilities...5 -
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
Just wanted to mention that Onshape fills different color for closed sketches for easy identification in sketch mode:
Closed shapes at left
//rami5 -
Good point, @3dcad
It's not specifically helpful in the OP case, though, because there the problem was not a gap, but a tiny overlap of entities, creating two enclosed sliver areas which remained unselected.
As a consequence, a pair of sliver cavities would have been created in the extruded body which butted together at a single point, created a "zero thickness geometry" situation.
If the OP had zoomed right in and selected the two enclosed sliver areas, the extrude operation would not have failed, if I'm right about zero thickness geometry.
ON EDIT
it just popped into my head when thinking of something else entirely: selecting just one of the two sliver areas should be enough for the extrude to succeed.5
If you carefully inspect the geometry of the first sketch, you will see there is a mismatch between two straight lines and two arcs.
This can be fixed by recreating the straight lines so their endpoints are coincident with the arcs, and tangent to them.
It also falls short of best practice (in that first sketch) that it is not fully constrained:
For robustness, sketches should all go black before you use them as the basis for further modelling
ANd zooming in on the area, I found a conflict...
ON EDIT
