Convert assembly directly to part studio
in General
I have a drivetrain that I have in assembly form, perfectly aligned and put together, that I need in single part form in a part studio so it is editable (as in cuts and adding things) and not as laggy. The only way I have found is to project it to a part studio and rebuild it from scratch, which could take hours. Is there any way to do this? So far the closest I have gotten is exporting as .stl and importing it, but that makes a mesh.
Is this drivetrain a model that was imported from another CAD system? Is it possible to share your project with us?
If it's an imported model, you can choose to import the assembly into a single part studio as a composite part. This will combine all the components into one single part that you can modify afterwards.
Hope this helps!
@John_P_Desilets can you elaborate how to import the assembly as a composite part? I don't see that as an option in the insert window.
Thanks.
BTW Solidworks said too big to open.
Mean time try using Parasolid format to export and import. As noted above, Assembly can be brought in as a composite in a part studio. Behaves as one part that can be modified.
.. and two years later I have to dig out this post. I miss this feature also. I used in other CAD, save assembly as part often while generation simpler models for kinematic exports. Would be nice to have also this function in onshape. Ex and import is unfortunatly some extra work.
Best
Niklas
Can you post a screenshot of this? I cannot find any floating dialog / button / menu item to "Translate copy all parts in position" in my Part Studio; but I can see the transparent parts which come from the assembly context (screenshot attached).
Do you mean I can then Derive each part and manually place it at the same location as the transparent items? I'm hoping there is a way to take all the position and orientation information from the assembly...
https://www.youtube.com/watch?v=RVt7MbhvhrQ
