Why my table legs not the same, if measures are?
arnis_vingrisarnis_vingris Member Posts: 6
Hej. I made table today, and i used loft to make table legs, on one side of the table it makes legs one way, and on oposite side other two legs are different, how to fix this.
Name of document galdsaarnija
  • glen_dewsburyglen_dewsbury Member Posts: 1,098 PRO
    edited June 10 Answer ✓
    There are some sketches in the original that are not aligned and matched with other sketches. The loft is twisting the legs because of this.
    Attached are a couple of samples that you may find useful.
    Better to mirror parts than to draw individually in sketches.
    Assembly will give BOM part count instead individual name/part number to repeat parts.
    This was the first one I saw. All others are base on 90x90 squares. The constraints are not working out.
    https://cad.onshape.com/documents/bc77422bae424ecbdaf2e389/w/0afd12a8963b6dccb67d28d9/e/5112a20df13e9af2f82fefba
    The loft is twisting due to the connection points it's using.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 228
    I assume this document? https://cad.onshape.com/documents/6a724d75617326e4de0a98dc/w/0557e2d7f23f0440b3895a63/e/90ef26e05d56d7f8898e944a
  • edited June 10
    This content has been removed.
  • arnis_vingrisarnis_vingris Member Posts: 6
    Meassurements are identical on both sides.
