sweep a constant profile along a 3d path while setting the orientation at waypoints along that path
eric_rollinseric_rollins Member Posts: 2 PRO
Can anyone point me in the right direction for creating a constant profile feature that sweeps along a 3D path where I can adjust the orientation at several points along the path? The sweep function does not seem to have this flexibility. I could use the loft I guess, but then I have to create normal planes at each waypoint and then recreate the profile sketch at each one because I can't use derive to import the sketch more than once (even with versioning, as far as I can tell). Also, I can't have the profile sketch just copy/pasted because I will need to update it as I go so copies need to be "live".
