sweep a constant profile along a 3d path while setting the orientation at waypoints along that path
eric_rollins
Member Posts: 2 PRO
Can anyone point me in the right direction for creating a constant profile feature that sweeps along a 3D path where I can adjust the orientation at several points along the path? The sweep function does not seem to have this flexibility. I could use the loft I guess, but then I have to create normal planes at each waypoint and then recreate the profile sketch at each one because I can't use derive to import the sketch more than once (even with versioning, as far as I can tell). Also, I can't have the profile sketch just copy/pasted because I will need to update it as I go so copies need to be "live".
I'd recommend either Super Derive to derive the same sketch multiple times or you can use the Transform Pattern feature to copy the sketch to a new location. Here is an example https://cad.onshape.com/documents/0c583f78cbb23aaa490174bf/v/00ebe8309f37d2707abc4234/e/98029e584845299241dfb654
Super Derive
https://cad.onshape.com/documents/cfef86ed4f9635531599a973/w/def12fa727cba59c54c7c45d/e/1ca336dd47d98dd00918c589
Transform Pattern
https://cad.onshape.com/documents/6b982e3c0a039b6d40984f18/v/127c578ceb9bd1e98f7b982e/e/c8af103a5f3d2ff7ae610be1
You can also turn one derived sketch into a surface and then transform/copy that body to the other locations. Flat surfaces or closed sketches both operate pretty much the same for lofting, etc.
@eric_rollins Use a ruled surface to make a reference for the sweep feature to use as a "face to lock".
In the Ruled Surface
In the Sweep
Here's an example I did recently of this.
@EvanReese thinking real hard about how I could simulate theoretical G force vectors on a curve to make an auto roller coaster script with this ruled surface approach as the basis. We've got some twisty ball track that's always been a bit of guesswork at figuring out the bank angles but it doesn't need to be.
