Best Way to create Hydraulic Hoses
Hi everyone,
I'm looking for the best way (as of 2025) to model hydraulic hoses in Onshape for simple hydraulic assemblies.
I already have a library of standard hydraulic components (see attached image), such as cylinders, pumps, valves, and fittings. What I'm missing is an efficient way to connect these components with flexible hoses — ideally in a quick and clean way, without manually drawing 3D splines and sweeps for each hose.
I'm aiming to build relatively simple hydraulic systems like the one shown in the second image.
I don’t need super realistic behavior (like hose dynamics), but I would like something that:
  • Connects two ports or faces in an assembly.
  • Automatically routes or bends nicely.
  • Allows me to specify a hose diameter and radius of curvature.
  • Ideally creates a Part Studio or solid body for the hose (for BOMs, etc).
I know there are Custom Features for cable/wire routing, but they seem more tailored to electrical harnesses than high-pressure hoses. I’ve also searched for something like a “Flexible Hose Generator,” but can’t find anything reliable or up-to-date.
Are there any custom features, workflows, or tips you'd recommend in 2025 for this type of task?
Any feedback or examples would be greatly appreciated!
Thanks in advance,
Maxime
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,967 image
    The Cable/Wire Routing feature will do hoses, just the terminology is different and the hoses are not hollow.
  • wayne_sauderwayne_sauder Member, csevp Posts: 639 PRO
    Here is a thread with the tool I use currently.
    https://forum.onshape.com/discussion/21957/hose-routing-feature#latest
  • stefanbregstefanbreg Member Posts: 4
    You can use the routing curve
  • maxime_merlaud563maxime_merlaud563 Member Posts: 5
    Thanks @wayne_sauder;
    The tool look very easy to use.
    How do you create a midpoint that you can easily move to control the path of your hose ? Do you create a routing curve first ?
