Mirror of sheet metal part
I noticed that I can't make a mirror of sheet metal part, is it not yet implemented?
1
TVP, Onshape R&D
You can mirror or pattern a sheet metal part after you add a 'finish sheet metal model' feature [as this converts the sheet metal to a normal part].
The only downside is you don't get the mirrored part in the flat pattern or table, you also get different behavoir for the move face command [and maybe some other] before and after the finish feature is added.
Thank you for using Onshape sheet metal. Support of mirror and pattern for active sheet metal model ( before Finish) is high on our list of improvements. Please submit an improvement request - it would help us prioritize it.
Been using mirror of sheet metal parts for some time now. No need to use finish SM part unless needed for some other purpose.
Samples here show 2 versions of mirrored SM parts. One uses a gap that gets 2 parts and shows that way in table. The other uses the end of original part for mirror plane with add function to get 1 part.
https://cad.onshape.com/documents/85f222d440a7235f5b7aff34/w/7f53e4cd944f6ebbe990303a/e/aa5536cdb040da9e868898a3
At my end it's still dosent work to mirror the sheet metal parts on the right way.
When I finish the sheetmetal part and mirror it, then I don't have a mirrored flat part.
When I mirror before to finish the sheetmetal part, then I have the mirrored flat part put its related to the wrong part.
I need this because I have seperated drawings for the mirrored parts. Or does I need to delete one drawing that I have the mirrored parts on the same drawing?
You have to mirror prior to finish sheet metal. or mirror the 'finished' part and use it to create a new sheet metal part.
