Improvements to Onshape - July 18th, 2025
2»
  • karel_workskarel_works Member Posts: 14 PRO
    Great update, thanks for your awesome never ending work on this fantastic tool.
    Configuration drag and drop is gamechanger (instead of move up endless times:))
  • shawn_crockershawn_crocker Member, OS Professional Posts: 900 PRO
    edited July 21
    I stopped reading after this
    • The assigned default value for a configuration input is now displayed in the configurations panel
    • Configured dimensions can be renamed
    • List values can be reordered by drag-and-drop
    • Configuration inputs can be reordered by drag-and-drop 😍
    • You can expand or collapse all configuration inputs in one click
    Thanks you sooooooooo much for this! This has been a pain for me for years.
    Continuing to read, Oh my god! I'm having trouble comprehending how so many pain points for me have suddenly been solves in one update. This is awesome!
  • STEGSTEG Member, User Group Leader Posts: 125 PRO
    Update 201 is one of my favorites! 🤩👏
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 885 ✭✭✭✭✭
    @Alex_Pitt I am experiencing the same thing. All my defaults are in inches. When I create a .dxf it defaults to meter. I change to inch it to inch but if I close the program it goes back to meter.
    Is there a default setting for .dxf export that can be set?
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Alex_PittAlex_Pitt Member Posts: 73 PRO
    edited July 22
    @bryan_lagrange Don't think so. If you're talking about drawings (rather than exporting from a part studio) I think it defaults to the units specified in the drawing, but I don't know how to change those. They may be locked into the DWT file of your drawing border. Before export, when you change the settings away from "Use drawing units", it does seem to remember the change for subsequent drawings in the same Onshape document. So you should only need to do it once per OS doc.
    My apologies. Onshape doesn't remember the export settings for particular drawings between sessions. Today, the export options were back to the default: "Use drawing units."
    But yes, it could be useful to set defaults for this in your company settings or user account preferences.
  • josh_grasby942josh_grasby942 Member Posts: 3 PRO
    Wow, this is a big one! Full spectrum of improvements both new and formerly requested. Great work everybody
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 295 PRO
    Can we allow for all Dimensions to be edited/renamed, not just configured ones.
    CAD Engineering Manager
    +1 to what @Jaro_Lansink posted.
    Bryan Lagrange
  • Conant_CustomConant_Custom Member Posts: 9 PRO
    I do not see Straight Pipe Tap as an option in the hole tool. The "Straight Tap" option seems to revert all settings to UNF thread styles. As a lighting manufacturer, 1/8 NPS is one of our most commonly needed threads.
  • Jacob_MarbleJacob_Marble Member Posts: 2
    The tapered pipe threads will be very handy for me. But, it looks like it is not yet supported for external threads. So we're only halfway there.
  • test_user242test_user242 Member Posts: 6
    I can't find the metric straight pipe tap option for a part I've designed - do I have to create a new part or something in order to be able to access it?
  • TinusTinus Member Posts: 4 PRO
    Pipe threads! Yes!
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 431 PRO
    YAAAAAHAHHAHA FINALLY DRAG AND DROP MOVEMENTS FOR CONFIGS… OMG I´VE BEEN WAITING FOR THIS ALL MY LIFE!"!!!!! Bye Bye right click- up - right click - up - …
    yes yes everything else is cool too but finally i have more free time in my life again because i no longer have to make 4 million clicks on hundreds of configs.
    Best regards,
    Axel Kollmenter
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 34 PRO
    Love being able to export from structured view. Can we add the ability to export multiple parts/drawings/etc. from this view as well? That would speed things up so much, especially since I have some of these parts scattered across different releases.
  • fred_burttfred_burtt Member Posts: 15 PRO
    I've got the same issue as @alex_pitt
    Dxf export default to meters is a huge pain. I output flats for laser cutting all day, and this feature has been running interference very effectively.
    Please make it default to the drawing units.
    Everything else seems great, keep up the great work!
  • LarkinLarkin Member Posts: 7 PRO
    I literally said "finally!" on every dot point in the configurations updates. TYSM
  • kev_keegkev_keeg Member Posts: 9 ✭✭
    Don't really know where this belongs - forgive if wrong place.
    Suggestion: there should be a button which when pressed shows ALL functions UNDER ALL BUTTONS.
    I'm not newbee - but i find myself spending lots of time trying to find a function i know exists - but don't know where!
    thanks
    DXF export units now default to workspace units. SOLVED!
    Thanks, guys!
    @fred_burtt I would check to make sure that it is not a document you have changed the default before. I just opened Onshape and made a new document to check and it still wants to export out meter even though my defaults are se to imperial.
    Bryan Lagrange
    I did create a new doc this morning, and it used the workspace default (inches).
    Just tried it again and it's back to meters. Spoke too soon!
  • EricMartinEricMartin Member Posts: 3 PRO
    We also need the dxf export to be fixed, or just put it back to the way it was.
  • SebastianMaklarySebastianMaklary Member Posts: 11 PRO
    We also want the DXF export to be changed to default to the document setting. It is fine being able to override it but having to actively set the scaling of every export is unnecessary extra time and sources of error added. I just came back to work after the summer and this was the first thing my boss asked me to fix because they have had trouble with it for weeks now.
