Third angle default
david_hollis
Member Posts: 2 ✭✭
Is it possible to add the setting of the projection type in the work space tab where we change to metric. Maybe even a choice that says Australian standards
Yeah this is actually quite a bugbear for Australian and NZ users; we used ISO standards for most things, but generally use third-angle projection.
I see we can manually override it in the Drawing Properties as well
