New Feature: Speaker Pattern
EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
Speaker Pattern takes a vertex or mate connector as input then patterns cylinders and performs a boolean operation to add or remove them from parts. See the example below:
I just got it to a usable state so I'm sharing here for people to use and so I can get feedback, and there is a lot of room to improve if/when I make the time:
  1. add more pattern types (any suggestions?)
  2. add end conditions like the extrude feature
  3. make default size values more practical
  4. find a way to visually clean up the middle of the Fibonacci pattern (even though it's mathematically "right")
  5. add an option to select a custom modeled shape to pattern instead of the default cylinder
  6. any other ideas?
I've been working on learning Featurescript, which is my first dive into programming in any language, and I couldn't have done this without lots of help from the forum. Special thanks to @NeilCooke @MBartlett21 @ilya_baran
 and @konstantin_shiriazdanov
  • S1monS1mon Member Posts: 4,091 PRO
    @EvanReese
    As it happens, I'm working on a something which needs a pattern of holes for a speaker, and I remembered this feature. It's working well, but it would be really nice to do something like Fill Pattern where you could choose a boundary and optionally a margin. It's not hard to tweak the dimensions to get there, but I suspect that since this was one of your oldest efforts, you might be able to tune this up a lot more easily now.
    I'd also love to see some more pattern options. I'm not sure where you'd stop, since there are zillions of them out there, but a few more would be nice.
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    Glad someone is using it! I've considered re-writing this one because, as you say, it's one of my oldest ones and I'd do it differently now. I'm not sure if/when I'd get to that, but would love to see some examples of other things you'd hope to accomplish with it. I've considered blending it with something like Attractor Pattern to accomplish things like this (though this has a bit more going on with the point placement).
    Again, I'm not sure where you'd stop - it's an infinite space, but here are some basic selection of ideas which I could see being incorporated:
    https://www.speaker-grill.com
    https://www.shutterstock.com/search/similar/428647408
    You can quickly go off the deep end with patterns on Pinterest, etc:
    https://www.pinterest.com/pin/439171401140112138/
    Yeah I get the gist, I love that kind of stuff, but it's hard to generalize to a single feature. For many of these I think you'd have to write a custom specifically to achieve that look, which is pretty much what the Grasshopper users of the world are doing, and could be done with FeatureScript too. This one was just meant to automate creating that classic look from Deitur Rams https://www.midcenturyhome.com/dieter-rams-music-player-tp1/
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 858 PRO
    @EvanReese I keep trying to get the Rhino jockeys in our office to learn featurescript to do the stuff they're doing in Grasshopper but they tend to be more visual thinkers for coding and don't mind writing a script that takes 20 minutes to run one-shot. They also like to abuse graphmapper inputs for everything and I haven't seen someone implement that yet in featurescript. The animate feature has something sorta like that going on but not for driving surface geometry or patterns. Might be another rainy day project to tackle some time if someone bugs me enough.
    edited August 2025
    I started but didn't yet finish a tool to use a sketch as a graph mapper. Definitely doable. This one remaps the numbers too so the min/max sizes stay the same and the graph controls how it transitions between them.
    Hey that's exactly what I was hoping that would look like when I was gonna get into it. Do you have support for piecewise paths for more complex forms?
    nice! what do you mean "piecewise paths for more complex forms"? like chains of curves?
    Yeah like say I want to start out and end with linear behavior but smooth between the two with some cubic Bezier curve or spline. Or if I wanted to draw the top half of the batman logo and use it to drive some geometry.
    Yeah that's totally possible but I didn't get there. Yet. This was more of a proof of concept. In the end it just spits out an array of values as a variable so I can get at them in any kind of pattern feature later with an iterator variable #i.
    @EvanReese did you ever dedicate any more work towards that graphmapper util? Your recent work with query patterns has me thinking about it again.
    @EvanReese Actually I've got a work-relevant need for some graphmapper utils plugged into other features. Any chance you can share the prototype version of the thing in the gif above even if it's not in a more polished state? Could save me some steps over starting from scratch.
    I have an IR for Lerp() functions which could also help with these kinds of things. Of course with my new found use of AI, I might just be able to build this myself (if I can find the time). Ideally it would be graphical which is tricky with Onshape.
    I have built stuff in Solidworks and Onshape that hack things for small numbers of inputs/outputs just using sketch functions - similar to @EvanReese 's example, but all within a sketch. You end up with a lot of equals constraints.
    @Derek_Van_Allen_BD you've got it bud (I even made it public before sharing).
    @S1mon I have a lerp function here, but you're right that an LLM would knock that out in 2 seconds.
