New Feature - Bridge Overhang (for 3D printing)
 imants_smidchens
                    Member Posts: 65 EDU
imants_smidchens
                    https://cad.onshape.com/documents/9db73769726a7c1968a9eec6/w/a94665f4983acd43414a91e8/e/f98a3b9885864c1f11d186d6
This tool lets the user print normally difficult geometry much more cleanly. Generally, when printing geometry with counterbored (or pocketed) geometry on the bottom, the resulting print develops a solid amount of spaghetti as filament is extruded with no support. Printing supports isn't much better, plus it requires the user to remove them afterwards, often resulting in poor print quality as well. No more! with the Bridge Overhang tool, geometry is modified subtly to make printing a breeze below are two sets of identical holes, printed with and without the geometry modification at .2mm layer height on a prusa mini.
The feature can be applied as a finishing step for all holes, including an automated selection process that can propagate the feature to identical parallel faces with the same orientation (see below)
Cheers, and happy 3D printing!
I love this tool, but am running into a problem (that with v14 may be user error)
I create a triangular overhang that would normally be able to be printed via bridging (with the bridging running at a 45 degree angle) and then want to put a hole in it.
When I use the bridging counterbore feature, it makes the lines vertical and horizontal, which leaves the bridges without support
I see that in v14 there is a toggle for 'auto locate bridging direction', but when I turn it off and select the edge of the overhang, the feature is not happy (red with an error). what do I need to do to pick the direction of the bridging?
never mind, I tried again and this time it worked
Completely missed this! Book marking now.
