How to achieve parametric- or feedback friendly design using frames
jan_viljan_vil Member Posts: 9
  1. Is it possible to somehow assign a variable to a frame profile, so when I need to change frame profiles of multiple frames, i could do it in one place not change every frame object separately?
2. Regarding limiting frame ends. If i change the frame profile I have to re do most of the 'limit frame ends'. Whats the best way of automating this, so that if a frame profile is changed, the other frames would adapt automatically?
3. When using frames, what's the best practice in taking account profile sizes - ie I have a critical dimension where a width of 2 frames needs to be X. Now when I change the frame profile, I would like the sketches to adapt automatically. Is the best way creating a measured variable of the frame and using that variable in the sketch dimensions?
4. When using frames, I can adjust where the frame is situated along the points (not sure how to call this gizmo, pictured below.. How could I choose different points for both frame ends, so I could limit the diagonal parts upper end to the frame (the overall angle needs to change as well). Ideally I would like to avoid making new points to the sketch and doing it manually, since changing the profile later means I have to re do this.
Thank you in advance!
  • MichaelPascoeMichaelPascoe Member Posts: 2,503 PRO
    edited August 8
    Hey @jan_vil!
    1. Yes, in a separate studio from your current part studio, draw a frame profile in a sketch. Then use the Tag feature to tag it's "Standard". You can right click and convert the "Standard" in the tag feature to an expression that inputs variables for the size of your frame profile sketch. Note this only works well downstream if the same sketch is used and the shape doesn't change but only the size changes. You can also change shapes this way too, but some things down stream may break.
    2. If you use the above mentioned method, you shouldn't have to re-do the frame ends.
    3. A measured variable is a good way, but there are ways to automate that as well. Try using the Aligned Bounding Box feature.
    4. For choosing a different start orientation and end orientation of a frame you will either need a custom feature, or you could manually create a fit spline between the diagonal corners of an untrimmed frame, then using mate connectors and the transform tool, transform the frame to the new diagonally based orientation.
    Another way to do frames which is more robust for assemblies, is to have a single configured frame part studio where the profile is set up how i mentioned so that down stream references don't break. From there you can configure it to have different angles on the ends as well as a configured over-all length. What this does is allows you to change profiles of your frame in the assembly, while maintaining all downstream references. This way takes longer to set up, but is very clean and robust in the end.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 194 PRO
    One thing I do miss about Solidworks is their implementation of the Structural System feature which allows you to define whole structural frames in their entirety in almost a single feature without having to do many single instances of frames / weldments. The global control possible with that tool was super nice. Frames in Onshape work a little weird at the moment in that they don't save information about their seed geometry in a way that can be reused (like sheet metal does) which makes implementing certain frame features a little difficult. I do have a prototype version of the frame tools that lets you select groups of faces or edges and evaluate them in order to handle branch cases that the tool doesn't currently support but it's got a long way to go before it's polished.
  • S1monS1mon Member Posts: 3,498 PRO
    @Derek_Van_Allen_BD
    I never used any other CAD system besides Onshape for Frames, but one of the things that prevents me from using a single Frame feature for my current project is that there's no way to individually set the locator points (defaults to 9 points) for each of the paths. Frame also won't handle certain topologies. I'd like to do more with a single Frame feature for a bunch of reasons.
    I just created this improvement request because I couldn't find anything like it:
    https://forum.onshape.com/discussion/28498/allow-frames-to-select-locator-points-per-frame-part
  • glen_dewsburyglen_dewsbury Member Posts: 1,135 PRO
    edited August 8
    You can add locator points while making a tag feature.
    The only way I know for adding to existing frame tag is to make a fame from existing and copy the end profile with new points added.
    @glen_dewsbury
    I've made a custom frame profile for one project and figured out how to add the tags. That's not the problem I was discussing.
    The issue I'm having is that this frame took multiple Frame features because I couldn't choose different points for different frame elements. Also the topology drove me to need more Frame features than I would have liked. In a few areas I could get several frame parts in one feature (see highlighted feature), but overall it was awkward. I suppose if I had started the reference sketches to all be on the center of the tubes it would have cut down on the complexity. But I wanted to reference corners which don't always work out neatly to be the same for all the elements.
    @S1mon I've got a number of projects I'm juggling right now where all the frame bodies are defined by edges or faces of solids and I'm currently getting around the cornering problem by moving faces in by half a frame width but that's not gonna be stable if I decide to change the frame standards at any point. All of these things are reasons I'm weighing a refactoring of the frames tool but to do it the way I'd really like I would need the ability to make a separate tab for the surface body definitions required to implement "simultaneous frames" like was done for sheet metal. That would definitely require some prerequisites to be met by the internal dev team at Onshape though.
    I have a variable for the frame size, and the frame is square tubing, so I could have done some stuff with 1/2 the frame size, but I didn't really consider that until I had gone down this path. If/when I do a lot more frames, I'll certainly plan things out a little differently.
    I'd also like to see some more flexibility with the frames feature, like the IR that I shared. I could also see things where a reference could be two points so I don't need to add 3D Fit Splines or Sketches or Routing Curves to add elements between some existing points/verticies.
    I'm sure that people that use Frames all the time have more wishes.
    @S1mon This explanation made the problem clearer. I have run into the same sorts of things so I voted for your IR.
  • jan_viljan_vil Member Posts: 9
    This is a great feature request. That feature would've saved me heaps of time. Another good thing would be to have the same feature on patterns as well.
    Thanks for your answer, much appreciated!
    Could you please elaborate on point 4, and also the last paragraph.
    edited August 11
    @jan_vil Sure thing:
    • Custom features: Onshape makes features in the part studio using the FeatureScript language and Feature Studios. They have given users access to be able to make their own custom features and even copy and modify existing standard library features directly from Onshapes feature sources. You can add custom features to your toolbar by going to the document link that contains the code for that custom feature, then press the (+) button at the top of the screen to add it to your toolbar.
    • Regarding the manual way of doing it: After thinking about it further, the best way to do this manually will probably be to create a guide sketch then use that to drive the frame path, like this. Remember to use the Cutlist feature to get a list of all the sizes. There is a default one, as well as a custom one I made for naming the frames and getting more data to the drawings: Cutlist+
      https://cad.onshape.com/documents/54a282082cc9d4a71c9e0ad2/w/0a6c3ceaeca20d5a45455e36/e/5f867d5183ccd04bb43… image.png .
    • If you want to only use the assembly, and insert frames directly into the assembly, you can do that by creating configured frames and frame profiles. This way when you insert the frame into the assembly, no matter which profile you choose, the mate connectors and downstream references stay the same and will not break. Stable Frame Assembly Example. Notice how the BOM table in the assembly correctly counts the frame parts if you do it this way, so no need to use the cutlist.
      https://cad.onshape.com/documents/54a282082cc9d4a71c9e0ad2/w/0a6c3ceaeca20d5a45455e36/e/718f3f8ad8f733535… image.png
