Parts Not Showing
GWS50
Member Posts: 491 PRO
I have many imported parts, one of which is a motor. When I try to place the motor into an assembly it doesn't show in the list of available parts even though I can access it in the Studio Part tab.
Why would this be and what am I missing?
1) You have imported motor to same document and work space.
2) Imported motor is solid body.(If it is in surface you can't insert it to assembly)
https://forum.onshape.com/discussion/1881/import-woes
