Face blend not completely seamless
s_b178s_b178 Member Posts: 4
Hello everyone,
I'm trying to do a face blend with a block to a cylinder but I keep getting this annoying bumps:
Comment Image
How do i change the face blend so that the block seamlessly connects to the cylinder?
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 386 image
    edited August 2025 Answer ✓
    Just based on what I can see in the image, this will take more than just a single face blend feature to achieve. It will need a bit of surface modeling, but not much.
    See example here:
    https://cad.onshape.com/documents/cc00aeaccfa37cd98094b575/w/5cc1d965e9f1477b471e4a83/e/7f64f8520e5081d654943d73
    I've exaggerated the "bump" you mentioned, it is not something that the face blend is designed to conform to.
    But I can use some of the edges created by the face blend! I copied them, mirrored them to the other side and created a single patch (using a Fill feature) that blends in perfectly. Do this again (deleting the face blend helper faces and you'll be done. There are a ton of other ways you could do this (e.g. create the curves directly, without the face blend helper feature), but basically creating a smooth surface patch from surrounding reference feature is the way. Just be careful not to introduce any ugly noise in the curves you use for subsequent surfaces…
    You might want to share a view/copy link to an example document - then people might be able to help
    See example here:
  • s_b178s_b178 Member Posts: 4
    Thank you, I managed to finish the design. Now I can use my loppers again!
