Standard notes and tables in drawings.
We have a number if standard notes and tables we sometimes use (but not always). Is there any way to include these in the drawing template or save/copy them from somewhere so we don't have to continually re-create them? I haven't found an easy solution yet. Thanks for any help.
For today, users place standard notes on their drawing templates and then remove them on newly spawned drawings from the templates - if they don't need them on that particular drawing.
I would probably make sure to "Move to" those notes and tables onto the title block, as most are located next to title blocks on drawings and this will also ensure they move along with the title block on sheet size change operations.
This is the best complete reference for constructing custom templates in Onshape: Best Practices for Creating Native Onshape Drawing Templates - Onshape Learning Center
@PeteYodis is this still in the IR backlog or has this been implemented?
@ry_gb A block library has not be implement yet. I've created a support ticket for you.
Any update on this? Big need for us.
@PeteYodis Add me to the support ticket, please.
