Shadow from point source?
Owen_MurphyOwen_Murphy Member Posts: 5
edited August 2025 in FeatureScript
Hey! Does anyone know if there are featurescripts out there that generate a shadow of a part from a point source? I've tried all of the related featurescripts (Shadow, Outline, Project Body), but they all seem to project the edges of a part from a planar light source as opposed to a point source. I can certainly do this manually for each part, but it seems like it could be possible to make a featurescript that could do this for any arbitrary geometry. Any help would be much appreciated.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 793 PRO
    Feels like a variation on the Solid Sweep problem, except you've got it in loft flavor instead. I've got some whitepapers that handle the swept case waiting for a rainy day to implement but this doesn't seem too far from that.
  • martin_kopplowmartin_kopplow Member Posts: 1,278 PRO
    Wans't there a ray trace FS published recently? I remember it being discused here on the forum.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 400 PRO
    There is a feature that projects the shadow onto the surface.
    But the shadow is for an infinite far light source, so its not quite what you're trying to do.
    https://forum.onshape.com/discussion/comment/61460
  • S1monS1mon Member Posts: 4,037 PRO
    From @EvanReese
    https://cad.onshape.com/documents/de8cbd559bd2dcc347c38ff3/w/3603b1286161ccca20f2e841/e/b1db47e3a33d6461f8e732c1
  • EvanReeseEvanReese Member, Mentor Posts: 2,852 PRO
    Optics won't be much help in casting shadows from a point source and I'm not aware of a feature that will. This kind of problem seems related to isoclines, but not perfectly so. One idea to force FeatureScript to do something like projection from a point is to scale the input body from the point till it is fully through the plane you're casting onto, then lofting between them somehow (face-by-face, splitting as needed?), which means I agree with @Derek_Van_Allen_BD that it's kind of like a Body Loft operation. For simpler things like your example, you can do this manually the same way, like this. For curvy shapes, i'm not sure yet.
    https://cad.onshape.com/documents/3ca15967b4931ac0ef7acfe1/w/c5cf855c1a9eb71dbe13c59f/e/428f838a03d7331e574e518a
  • Owen_MurphyOwen_Murphy Member Posts: 5
    Thanks for the help guys. I was also wondering if there was a way to do a swept body - interesting that it's been discussed before. I attempted to recreate that by doing a linear pattern + scale at really small intervals and booleaning them all together. Pretty disgusting brute force strategy, but even that failed to be robust to any complex geometry.
    I'll keep exploring..
    The classic case for swept bodies it to simulate CNC cutting tools. I imagine something like that will make it to Onshape eventually for that reason.
  • robert_semenoffrobert_semenoff Member Posts: 6 ✭✭
    I suppose you could export the model, convert it to a format (like .obj) that a actual raytracer can use. But then getting the result back into onshape (if you need that) is another headache
