Notes, The Least Loved Part of Onshape
S1monS1mon Member Posts: 3,688 PRO
edited August 27 in Drawings
I have to say, putting in standard drawing notes that don't look terrible, is one of the hardest and least rewarding parts of Onshape. The formatting tools are slow, buggy and clearly only tested with limited scripted interactions. The preview (before you close editing) is completely different than the real note display. Flag notes completely blow up the line spacing, especially a default sized triangle note. And trying to manage bulleted lists under a numbered note is extremely twitchy.
We want this:
When we create a drawing template, we can carefully noodle around with the formatting tools and set the triangle flag to "tight" spacing to get this. When we export to a DWT, the triangle gets converted to lines which are pasted behind the text, so it's no longer parametric and linked. WTF!?!
If we're being more accurate, flag notes shouldn't have periods in them. Creo, Inventor, etc can do this. This isn't rocket science.
  • S1monS1mon Member Posts: 3,688 PRO
    While I'm ranting about drawings, why are leaders for dimensions formatted differently from bend notes? Why would anyone want the leader to touch the text for bend notes?
    Another fundamental issue is there's no way to put GD&T in a note, which is something that I've seen as a standard at multiple companies over my career. In order to do this, we're manually dragging a separate GD&T callout separately from the note, and the note text has a bunch of spaces to make a hole for this.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 54 PRO
    edited August 29
    I had to do this shit exactly a few months ago. It hurt my soul...
  • martin_kopplowmartin_kopplow Member Posts: 1,035 PRO
    edited August 29
    I wonder why there is not just the usual well learned standard text editor interface available in the notes, or any text, EG in the title block. There must be tons of sample codes around. Also, in tables, there should be a standard spread sheet interface like we all know it. Why reinvent the wheel yet another time?
    Part of the challenge is that while the adoption of Unicode has made it a lot easier to add all kinds of specialized symbols to regular word processing and text editing applications, most of the symbols in mechanical drawings are still a bunch of roll-your-own problems. Unicode has a series of circled numbers, but nothing for other styles of flags, and GD&T has a lot of special symbols which aren't in Unicode at all.
    I haven't used Pro/E (now Creo) for ages, but at least when I was using it, the notes editor was all ASCII based and all the special symbols and formatting was encoded by some sort of escape characters. A little convoluted and not WYSIWYG, but it did work smoothly. I don't want to go back to that method, but it was a lot less twitchy and painful. To be fair, there was one fixed width font (made to be used on pen-plotters), and that was it.
    When you see what they can do with custom symbols and precise formatting and layout in Figma (also web based), it's clear that it's possible to do well.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,432 PRO
    Speaking for annoying things with notes: wanna mention there is still no spellcheck in there? This one kills me considering we have spellcheck for feature names and virtually everything, except for the most important place!
  • EvanReeseEvanReese Member, Mentor Posts: 2,654 PRO
    Agreed. Currently fairly painful.
  • Jack_BrentanoJack_Brentano Member Posts: 12 PRO
    I'm waiting 5 seconds minimum for what I type to appear once the note block gets large enough. I see you made the post from a few years back talking about this issue and nothing seems to have changed.
  • GWS50GWS50 Member Posts: 490 PRO
    Agreed, drawing notes always fills me with dread. I have to steel myself for a slow and frustrating time when putting in notes on a drawing, the formatting really sucks
