@Philip_Thomas_PTC I think that's a very sensible rollout strategy. I don't mean to imply that it should already be implemented, but wanted to add my thoughts now in case there's ongoing discussion for the future, which it sounds like there is! Thanks for the reply
Excellent updates! The include properties checkbox is something we have been wanting to help keep our library clean. Is there a way to change the default to leave that box unchecked? That is typically what we want in our workflows.
@Philip_Thomas_PTC
I was imagining that we get a workflow much like creating a new regular variable while in sketcher (or other situations). You could create a QV while in another feature and the QV would be added to the feature tree right before the current feature. This would be an explicit QV. If you delete the feature that was used to create the QV, it would still exist, just like a regular variable.
Evan's second concept is more of a parallel with implicit mate connectors. I could see that being useful to keep the tree less cluttered, but much like implicit MCs, I often later want to be able to reuse them, and there's currently no way to do that. I'd almost prefer that those MCs got added before the feature the same way on-the-fly variables do. It would be more consistent and make them more useful. I suspect that part of the reason for that workflow was that at the time, MCs needed an owner. Now that they don't, I don't see why they shouldn't be created above the feature for potential reuse.
Ok, guess my Query Finder isn't deprecated just yet.
I've added an option called "Convert to Query Variable" to the
Set Query Attribute feature. This will let us still use attributes and expressions but convert the results to a Query Variable. Not ideal as it takes extra steps but the functionality is there.
Query Variable Feedback:
These are some important points. If we can't use expressions, it really limits the amount of automation we can achieve.
https://cad.onshape.com/documents/e198b079c4791595b0cdfaac/w/65a5fada7da994fea64570c0/e/0c8a11432c9a0ab7ac…
RENDERCAD
Great update, congrats to everyone envolved!
In future I would love to see an option to export Document Notes as PDF.
I think it would be pratical as a way of making the Instructions on the Document Notes and then have the possibility to export as PDF, so it can be printed and shared on the shop floor in areas were there isn´t a computer yet.
Is there a way to markup a pic in the "Comments" and add it to the "Document Notes"? They seem a bit redundant. Not complaining, I like them both. I just do better with pictures.
Love querry variables.
I can certainly see use-cases for richer content in this panel. I'd love to embed videos here to include a tour for top-level things in a multi-document top-down model. I'll settle for urls for now.
Standard Markdown seems to work for both image and video! https://cad.onshape.com/documents/08af2a4f125a980f501dcc2e/w/026a96708185c5044c9f33f1/e/41b7387412e8ea737fcfedbf
Has the query variable and some other updates not been rolled out to enterprise accounts yet? I see document notes but missing others.
This markdown syntax seems to work so far. I can link to spreadsheets!!!!
https://www.markdownguide.org/basic-syntax/
Everybody should see it by now. Probably, the workspace you are in is at the old version. Try Humburger menu/ Update workspace.
Already getting my mileage out of the new query variable functionality and adding some new functions to it to help clean up some of the topological messes people send my way. I'll probably find some way to shove frame and sheet metal properties in here as things to query by at some point too.
Derek Van Allen | Engineering Consultant | MeddlerPCB Studio is heading in the right direction. If a full MECAD solution is realized, Onshape really will become an industry staple in no time.
@Derek_Van_Allen_BD
Very cool. I'm very curious how you add the tolerances. I guess I need to look at the official code for the query variables.
I very much want to see a good query that will find all the corners of a sheet metal part that need a corner break (fillet) for handling. Right now I can do a good job with simple parts (convex edges of the part, intersected with matching edges), but I'd like to skip things where there are slightly convex artifacts or tiny steps due to weird relief cuts. I can't see an easy way to do this, but I suspect that someone could write a "Query Variable Plus" or a "Corner Break Plus" to do this.
@S1mon like this. There's a flood fill option for qTangentConnectedFaces() that has a tolerance bounds that I'm exposing to the user here. Lets me select one of these wonky edge faces and grab the whole chain without grabbing the bits I don't want. You can also see the start of some of my mesh reverse engineering scripts in some of those other tabs. I have an open improvement request to be able to expose mesh triangles to featurescript precisely because I want to do this sort of power selection of faces into groups and replace them with parametric faces like true cylinders or planes. Can't do that with just vertices.
Derek Van Allen | Engineering Consultant | MeddlerI got very excited when I saw "import improvements", alas…no SVG or STL direct import options.
Query Variable! Nice!
Now we don't have to write up a niche featurescript for a simple task like this anymore.
I did sometimes finding myself making a one-off custom feature specifically to make one tricky selection never to be used again.
"…If we can't use expressions, it really limits the amount of automation we can achieve…."
100% agree.
Which is why I've not understood why simply supressing a feature with an expression is not possible yet? yes there are some work arounds, but why not have "suppress feature" convert to expression option like you do with Booleans?
I think suppression is not easy to make driven with variables because its a different control layer in part studio code representation. Note the if(false) or if(true) wrappers around feature invocations, these true/false values is what defines whether feature is suppressed or not under the hood, and you can see they are not being feature parameters
Thanks @Konst_Sh
We have been cloning native features as a custom feature, then adding a suppression box within them, then converting this to an expression as we need it. The issue is of course they don't update and develop as Onshape adds and improves functionality. So we end up with the Onshape native versions, and our versions, and then they drift apart slowly.
I'm very happy to see query variables come to Onshape! Can't wait to put them to good use!
I finally got around to playing with Query Variable in a real model and it's insane, as a person who doesn't make his own FeatureScripts. It adds Grasshopper functionality within parametric CAD. Way to make selection sets ACTUALLY useful, guys …
Edge selection for lofting is always a pain, especially when edges go missing or a selection breaks. The ability to select all the edges of a surface and then add additional queries to narrow that the selection pretty much guarantees you're selecting what you want every time.
Kudos to the Onshape team! I expect every competitor is going to be copying this one.
Ramon Yip | glassboard.com
Doc Notes, yes! especially for analysis
QV's amazing! Can't wait for vendors to build public parts for their products. I'd use'm.
I am sorry QUERY VARIABLES. I cant se any use of this in my design work maybe I don't fully understand it.
Derived properties is very important for me.
I want the name appear in the feature list most important
@svenolov_nystrom for a good example of query variable look at @Derek_Van_Allen_BD's image.
Imagine selecting all of those faces, then changing the shape then most of the faces error out. You would have to go back into the feature and reselect the missing faces, or possibly all of them if the shape changed too much.
With query variable, you would select one of the faces, and let the query variable look for the rest automatically. If you change the geometry, it will automatically update the selections for you. If it fails on a couple and you have to do some reselecting. You do it by selecting one or two of the new faces in query variable, and that's it.
It would be great if the Notes copied over when you copy a workspace containing notes to a new workspace.
Part of the process I developed within onshape for our company relies on copying a workspace with a folder structure and a drawing that has already been started.
We currently use pre-filled out txt documents saved in project folders in google drive to capture critical information about the project. It would be great if we could incorporate that part of our workflow into onshape.
That would be more than great.
It would be a nice place to add lessons learned for the next project. Something that is easy to overlook when you have to dig into old history each time.
I was hoping to write out some class instructions and have them copied in Classes. Being markup, it wasn't difficult to post and have the students copy and paste it in for now - but I hope that Document notes will be copied in the future.
Document Notes are independent of History - meaning: if you go back to an old version of the document, you see the Document Notes as they are today - NOT as they were when that version was created.
I think I'd prefer the Document Notes were part of the History & Versioning…otherwise, they can't be trusted as immutable data that was collected at the time of a version. No longer useful to build the development story for IP, for instance.
