Handling without a Mouse
urs_egger099
Member Posts: 12 ✭✭
Hi there,
I'm trying to handling my models and drawings on a business notebook with trackpad and touchscreen - but without a mouse. That is the case while being travelling at the airport, on a train or so. Usually there is also no table and I have my notebook on my knees.
Rotate: right trackpad button + trackpad --> not so easy to handle but let's say that's okay
Pan: Ctrl + right trackpad button + trackpad --> seriously? that's horrible handling
Zoom: Pinch trackpad --> way too sensitive, cannot accurately zoom to the region I want
Using the touchscreen doesn't work at all (neither in pc mode nor in tablet mode - it just zooms all browser content)
Does anybody know another way to handle my 3d space without the mouse?
Thanks a lot for your feedback
Urs
You can also utilize the keyboard shortcuts
Twitter: @bradleysauln
That is a good workaround. Needs some training though.
But is there some way to use my touchscreen directly as I would on a Android or iOS tablet?
regards,
Urs
- Click and drag with two fingers (right-click) -> rotate
- Click and drag with three fingers (middle-click) -> pan
- Swipe up and down with two fingers (scroll) -> zoom in and out smoothly respectively
However, I am using Pop!_OS (a Linux distribution), so it's possible that not all of these touchpad gestures work the same on your system. I know that they also work on ChromeOS. Also, not all touchpads support these sorts of multitouch gestures, and they do require a "click anywhere" touchpad rather than one with distinct buttons. If your touchpad does have separate left/right-click buttons, it might be possible to click them both at the same time to input a middle-click.@alnis is my personal account. @alnis_ptc is my official PTC account.
My 2017 MacBook Pro trackpad works like a champ when using Onshape
PAN
ROTATE
ZOOM
all work great on MacBook Pro
To zoom — a lot of times I just FLICK two fingers and it does a nice smooth zoom. Then a two finger touch to stop the zoom
I can use two fingers to "right-click", but it doesn't seem to recognize "right-click+drag". Its a similar story with the three-finger gestures as a replacement for the middle mouse button.
The best I can do with my computer - my touchpad does have a "right-click area" in the bottom right corner. So, I can click that corner with one finger (or a thumb) and drag the other finger around to rotate. But there's no option for middle-click and drag.
Just tried the same on a Microsoft surface. It is the same as with a standard notebook.
ZOOM OUT & IN
2 finger brush away
2 finger brush towards me
PAN
Hold CONTROL then 2 finger press & hold while sliding
ROTATE
Hold OPTION then 2 finger press & hold while sliding
Thanks. Unfortunately pan and rotate don't work. It just zooms in/out since I have two fingers on the trackpad. Tried a force click with two fingers, and a tap with two fingers. Nothing. I've been using apple track pads for 15 years now, I'm very familiar with them. And these gestures (similar) work great in Fusion. I must have some setting wrong somewhere.
OnShape has the best controls for MacBook functionality. If settings are set to ACAD then the touchpad will only zoom in and out.
