Improvements to Onshape - August 29th, 2025
2
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    @Philip_Thomas_PTC I think that's a very sensible rollout strategy. I don't mean to imply that it should already be implemented, but wanted to add my thoughts now in case there's ongoing discussion for the future, which it sounds like there is! Thanks for the reply
  • Rhett_RobinsonRhett_Robinson Member Posts: 169 PRO
    Excellent updates! The include properties checkbox is something we have been wanting to help keep our library clean. Is there a way to change the default to leave that box unchecked? That is typically what we want in our workflows.
  • S1monS1mon Member Posts: 3,782 PRO
    @Philip_Thomas_PTC
    I was imagining that we get a workflow much like creating a new regular variable while in sketcher (or other situations). You could create a QV while in another feature and the QV would be added to the feature tree right before the current feature. This would be an explicit QV. If you delete the feature that was used to create the QV, it would still exist, just like a regular variable.
    Evan's second concept is more of a parallel with implicit mate connectors. I could see that being useful to keep the tree less cluttered, but much like implicit MCs, I often later want to be able to reuse them, and there's currently no way to do that. I'd almost prefer that those MCs got added before the feature the same way on-the-fly variables do. It would be more consistent and make them more useful. I suspect that part of the reason for that workflow was that at the time, MCs needed an owner. Now that they don't, I don't see why they shouldn't be created above the feature for potential reuse.
  • MichaelPascoeMichaelPascoe Member Posts: 2,689 PRO
    edited September 3
    Ok, guess my Query Finder isn't deprecated just yet.
    I've added an option called "Convert to Query Variable" to the SetQuery.png Set Query Attribute feature. This will let us still use attributes and expressions but convert the results to a Query Variable. Not ideal as it takes extra steps but the functionality is there.
    Query Variable Feedback:
    • The implementation is beautiful, but doesn't work with my main use cases for it. I'm less worried about it cluttering up the tree than I am missing functionality.
    • Doesn't allow expressions in the name field
    • Isn't working in feature patterns
    • When getting variables, I can't use an expression
    These are some important points. If we can't use expressions, it really limits the amount of automation we can achieve.
    https://cad.onshape.com/documents/e198b079c4791595b0cdfaac/w/65a5fada7da994fea64570c0/e/0c8a11432c9a0ab7ac…
  • catarina_henriquescatarina_henriques Member Posts: 8
    Great update, congrats to everyone envolved!
    In future I would love to see an option to export Document Notes as PDF.
    I think it would be pratical as a way of making the Instructions on the Document Notes and then have the possibility to export as PDF, so it can be printed and shared on the shop floor in areas were there isn´t a computer yet.
  • bill_schnoebelenbill_schnoebelen OS Professional, Developers, User Group Leader, csevp Posts: 130 PRO
    Is there a way to markup a pic in the "Comments" and add it to the "Document Notes"? They seem a bit redundant. Not complaining, I like them both. I just do better with pictures.
    Love querry variables.
    I can certainly see use-cases for richer content in this panel. I'd love to embed videos here to include a tour for top-level things in a multi-document top-down model. I'll settle for urls for now.
    Standard Markdown seems to work for both image and video! https://cad.onshape.com/documents/08af2a4f125a980f501dcc2e/w/026a96708185c5044c9f33f1/e/41b7387412e8ea737fcfedbf
  • joseph_aronov588joseph_aronov588 Member Posts: 1 PRO
    Has the query variable and some other updates not been rolled out to enterprise accounts yet? I see document notes but missing others.
    This markdown syntax seems to work so far. I can link to spreadsheets!!!!
    https://www.markdownguide.org/basic-syntax/
  • lanalana Onshape Employees Posts: 746 image
    Everybody should see it by now. Probably, the workspace you are in is at the old version. Try Humburger menu/ Update workspace.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 465 PRO
    Already getting my mileage out of the new query variable functionality and adding some new functions to it to help clean up some of the topological messes people send my way. I'll probably find some way to shove frame and sheet metal properties in here as things to query by at some point too.
  • jacob_mader375jacob_mader375 Member Posts: 2
    PCB Studio is heading in the right direction. If a full MECAD solution is realized, Onshape really will become an industry staple in no time.
    @Derek_Van_Allen_BD
    Very cool. I'm very curious how you add the tolerances. I guess I need to look at the official code for the query variables.
    I very much want to see a good query that will find all the corners of a sheet metal part that need a corner break (fillet) for handling. Right now I can do a good job with simple parts (convex edges of the part, intersected with matching edges), but I'd like to skip things where there are slightly convex artifacts or tiny steps due to weird relief cuts. I can't see an easy way to do this, but I suspect that someone could write a "Query Variable Plus" or a "Corner Break Plus" to do this.
    @S1mon like this. There's a flood fill option for qTangentConnectedFaces() that has a tolerance bounds that I'm exposing to the user here. Lets me select one of these wonky edge faces and grab the whole chain without grabbing the bits I don't want. You can also see the start of some of my mesh reverse engineering scripts in some of those other tabs. I have an open improvement request to be able to expose mesh triangles to featurescript precisely because I want to do this sort of power selection of faces into groups and replace them with parametric faces like true cylinders or planes. Can't do that with just vertices.
  • joshua_wolff546joshua_wolff546 Member Posts: 4
    I got very excited when I saw "import improvements", alas…no SVG or STL direct import options.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,002 PRO
    Query Variable! Nice!
    Now we don't have to write up a niche featurescript for a simple task like this anymore.
    I did sometimes finding myself making a one-off custom feature specifically to make one tricky selection never to be used again.
  • robert_stilesrobert_stiles Member Posts: 149 PRO
    "…If we can't use expressions, it really limits the amount of automation we can achieve…."
    100% agree.
    Which is why I've not understood why simply supressing a feature with an expression is not possible yet? yes there are some work arounds, but why not have "suppress feature" convert to expression option like you do with Booleans?
  • Konst_ShKonst_Sh Member Posts: 107 PRO
    I think suppression is not easy to make driven with variables because its a different control layer in part studio code representation. Note the if(false) or if(true) wrappers around feature invocations, these true/false values is what defines whether feature is suppressed or not under the hood, and you can see they are not being feature parameters
    Thanks @Konst_Sh
    We have been cloning native features as a custom feature, then adding a suppression box within them, then converting this to an expression as we need it. The issue is of course they don't update and develop as Onshape adds and improves functionality. So we end up with the Onshape native versions, and our versions, and then they drift apart slowly.
  • jelte_steur_infojelte_steur_info Member Posts: 606 PRO
    I'm very happy to see query variables come to Onshape! Can't wait to put them to good use!
    edited September 9
    Doc Notes, yes! especially for analysis
    QV's amazing! Can't wait for vendors to build public parts for their products. I'd use'm.
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 84 PRO
    I am sorry QUERY VARIABLES. I cant se any use of this in my design work maybe I don't fully understand it.
    Derived properties is very important for me.
    I want the name appear in the feature list most important
    @svenolov_nystrom for a good example of query variable look at @Derek_Van_Allen_BD's image.
    Imagine selecting all of those faces, then changing the shape then most of the faces error out. You would have to go back into the feature and reselect the missing faces, or possibly all of them if the shape changed too much.
    With query variable, you would select one of the faces, and let the query variable look for the rest automatically. If you change the geometry, it will automatically update the selections for you. If it fails on a couple and you have to do some reselecting. You do it by selecting one or two of the new faces in query variable, and that's it.
  • Nick_Adams85Nick_Adams85 Member Posts: 1 PRO
    It would be great if the Notes copied over when you copy a workspace containing notes to a new workspace.
    Part of the process I developed within onshape for our company relies on copying a workspace with a folder structure and a drawing that has already been started.
    We currently use pre-filled out txt documents saved in project folders in google drive to capture critical information about the project. It would be great if we could incorporate that part of our workflow into onshape.
    That would be more than great.
    It would be a nice place to add lessons learned for the next project. Something that is easy to overlook when you have to dig into old history each time.
  • kate_leipoldkate_leipold Member Posts: 7 EDU
    I was hoping to write out some class instructions and have them copied in Classes. Being markup, it wasn't difficult to post and have the students copy and paste it in for now - but I hope that Document notes will be copied in the future.
