Sketch is not contrain
in General
It's very hard to solve this without access to a public document, but…
I can see that there's something done with offsets. If you've trimmed them, sometimes you're left with stray points which may be coincident with other vertices, but without being properly constrained. I would look carefully at each vertex and see if there's more than one point there.
It looks like offsets might be involved. If you’ve trimmed them, you could end up with stray points that overlap with other vertices but aren’t properly constrained. I’d carefully check each vertex to see if multiple points are in the same spot.
Thank you . the radius on a sketch was duplicated . . . i found and corrected .
It looks like your sketch isn’t fully constrained even though you’ve added dimensions. Make sure to check for missing geometric constraints like coincident, horizontal/vertical, or tangent. Sometimes, lines may not be fully connected or there might be small gaps. Try dragging parts of the sketch—if anything moves, it’s still unconstrained. Also, check that everything is anchored to the origin or a reference plane. Hope that helps!
It sounds like your sketch might still be under-defined despite having dimensions. Keep an eye out for missing geometric constraints like perpendicular, tangent, or coincident—those are easy to overlook. Also, try gently dragging parts of the sketch; if anything shifts, it’s a sign there’s still something unconstrained. Make sure your base geometry is fixed to the origin or a known reference point. That usually helps lock everything down properly.
That’s a common issue, especially when working with more complex sketches. Sometimes it helps to use the “Show constraints” option to spot anything missing, and then add dimensions or constraints one by one until everything turns fully defined. Keeping the sketch simple and building up gradually can also prevent it from becoming under-constrained.
It’s also worth checking if any overlapping lines or duplicate geometry are causing the sketch to stay under-constrained. Sometimes deleting and re-drawing the problem area can resolve it faster than hunting for the missing constraint. Keeping constraints organized from the start makes troubleshooting much easier later on.
it looks like you’ve added dimensions, but the sketch is still under-defined. This can sometimes happen if there are missing geometric constraints like coincident, horizontal/vertical, or tangent relations. Try checking if any lines or points are still “blue” instead of “black” — that means they aren’t fully constrained yet. Also, make sure you don’t have overlapping or duplicate entities, since that can prevent the sketch from locking down properly
It sounds like the issue might be related to missing constraints or overlapping geometry. Double-check if all lines are fully defined, and try using “Fix” or “Coincident” constraints where needed. Sometimes even a small gap can prevent a sketch from being fully constrained.
Looks like the issue stems from offset trimming leaving behind duplicate or nearly coincident vertices that aren’t constrained. Inspect each vertex for unintended duplicates, merge/weld any overlapping points, and reapply proper constraints. Also run a cleanup (remove doubles / snap vertices) and re-check edge/face connectivity.
@lougallo
Admins…. I think these might all be fake accounts using chatgpt to answer and/or copy paste…
