How do I add spiral fluting
in General
Making a printable fencing sword handle and want to have spiral fluting. I have a good shape, but cant figure out how to do the fluting on the complex shape.
https://cad.onshape.com/documents/b8a9f8494650bd9bc21d4c07/w/163360045836a39277fad2df/e/59e310a964f6a29f2eb9dc07?renderMode=0&uiState=68d5962c2208dcc3be6027f8
Here's one solution.
https://cad.onshape.com/documents/121a17a8c4d8d48f36341867/w/2a863093fd12c99de7827019/e/d7581c7507bad0f1b22a6646
Thank you so much! This is exactly what I was looking for! Is it possible to use a circular pattern if I want to have offset spirals (every 90 degrees). Thank you!
Because the shape is only symmetrical about one plane, I think you'd have to make one more, starting 90 degrees off. Then pattern the two sweeps 180 degrees. Here is the first one patterned 180 degrees.
