How to form a Helix along a 3D curve
christopher_auger_dominguez
Member Posts: 2 PRO
I have a bent tube of the same diameter that has turns. I'd like to create a helix that follows the center line of the tube. I can't figure out either to create a curve/spline from the center point of the tube and/or create a Helix that follows the center line or follows the tube.
S1mon
Member Posts: 3,768 PRO
You may want to create the centerline of your tube first, and then sweep it.
After that, take a look at this FeatureScript from @konstantin_shiriazdanov
https://cad.onshape.com/documents/59007ff281e43510ea3797a2/w/a6cb15bca8f1b2bf6e312ccd/e/7517d8bd0162caff9f9cb2a7
2
@S1mon im also facing this problem but my path is 3d not like 2d like the one above, And i tried this method but it wont work
I want to make some thing like this but in onshape
Is there any way to do that ?
@shin_chan990
You could try my helical path feature:
https://cad.onshape.com/documents/07469e1ecb66233675cf1e17/w/640e35f8ac294f2435fbcefd/e/b7c9c0f661277e76b9a76087
