Is it possible to design 3rd part plugins?
thales_maiathales_maia Member Posts: 10 EDU
In my classes, I use onshape as a (pre)pre-processor for finite element analysis. After drawing the model I export for another software to work with.
Is it possible to couple the design with my program? First idea is just use local python. Second idea is use some "developer space" inside onshape and design my own fem.
I couldn't find any visible location to make that. Is is possible? If so, where can I read more about it?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 846 PRO
    Not exactly clear what you're trying to do, but yes, Onshape enables 3rd party apps.
    https://onshape-public.github.io/docs/
  • thales_maiathales_maia Member Posts: 10 EDU
    I'm sorry for not making myself clear. One question you've answered. I will use REST API to communicate with my local python program.
    The second one is: in order to transform my program into a onshape app, do you have any SDK? If not, API is still the way to go?
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    @thales_maia : You can develop apps to work with Onshape. Documentation is here : https://onshape-public.github.io/docs/app-dev/
