Dimension in Detail View
Is it possible to create a dimension in a Detail View that references geometry outside the boundary of the Detail View. For example, I want to show the radial distance of a feature but the center of the radius is not included in the Detail View.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,992 PRO
    As long as you can click on the arc you should be able to add a radius dimension
  • Otto_DeRuntzOtto_DeRuntz Member Posts: 26 PRO
    I have a similar need. It is common to need to create a dimension, like a diameter dimension in a Detail view where the centerline or both sides of a diametrical surface are not visible. Attached is an image of a couple ways this is represented from CREO
  • Santiago_Galvez_PortaSantiago_Galvez_Porta Member Posts: 2
    The feature requested in this thread is essential for correct dimensioning of mechanical manufacturing drawings. Please, can we get it integrated ASAP?
