Assembly update after part development/modification
seb_vanouseseb_vanouse Member Posts: 2
Dears,
I'm facing a problem I cannot solve up to now….
I started the design of a new part in an assembly using the button"create part studio in context". Up to this, it's working fine, and so I can design the first part, a first extrusion., and a new part file was created. I also suceeded to design a second extrusion, without any problem.
Then, I 've to make others extrusion, and the problem came at this point, I designed a third extrusion, this extrusion is present in the part studio, but can not be visible in the assembly file !
Assembly view,
part studio view, showing the third extrusion (in yellow)
I tried the command "edit in context", and again, I can show the third extrusion, but clicking on "go to assembly", I'm still back with only two exxtrusion, the third one is missing
the only way to "solve" this problem is to insert manually the third part, and redo the positioning using mate, long and complex process
so, my question is the following : is it a way to have an automatic update of the design of the newly created part in an assembly, reflecting the modification made to the part ?
many thanks for your comments and answers
regards
  • Matthew380Matthew380 Member Posts: 50
    Unfortunately, there is no current way to make a part studio automatically update parts into a assembly. You can just add the parts manually into the assembly by just clicking insert at the top and do it that way. If you truly want to get a auto load feature you can make a sub assembly and link the sub assembly into the main assembly (however you will still need to add the parts manually into the sub assembly to do this).
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    You can also use the "insert part studio" button, but it would require you to remove the in-context part from the assembly and re-insert it again.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 747 ✭✭✭
    Is it necessary new extrudes to be separate parts? It kinda looks like they might be meant to be all one part. - Scotty
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,060 PRO
    edited October 2025
    I don't think you need "in-context" design for what you are doing. A regular part studio with all the parts drawn together should be much simpler.
