Arranging text in a circular array
hansrudolfhansrudolf Member Posts: 55 ✭✭
Again one of the problems where I found no solution. Not even the AI could help…
I'm trying to set numbers around a circle, so that the text is tangential to that circle. I could draw the rectangles which should contain the text, but when I try to set the text it comes up in some oblique angle
https://cad.onshape.com/documents/5935e8d7ef8157145f5f05f3/w/8743202fb7bcd97befb0ffba/e/068a024a549426b7b4e83622
I hope it is clear what I mean.
Thanks for your help
  • robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
    Perhaps the feature script discussed in this post might be applicable. - Scotty
  • hansrudolfhansrudolf Member Posts: 55 ✭✭
    Many thanks Scotty, your answer hit the nail on the head. After some experimenting with the parameters in that script, I got a perfect result.
    This success begs the question: is there somewhere in Onshape a (searchable) library of all feature scripts? How should a user find a script that he might need?
    Kind regards,
    Hansrudolf
    Here is one resource. Have fun. Perusing the site is intriguing.
    There is a search tool within a document
  • jnewthjnewth Member, OS Professional Posts: 102 PRO
    @hansrudolf You can also try fs.place. It's not heavily used but I keep posting it so that people will slowly start adding their FS there.
    Well, that's great. I already have seen scripts which could be useful for me.
    I just hope I remember all this - but the forum entries seem to stay forever.
    Thank you all, and kind regards
    Hansrudolf
