Arranging text in a circular array
hansrudolfhansrudolf Member Posts: 54 ✭✭
Again one of the problems where I found no solution. Not even the AI could help…
I'm trying to set numbers around a circle, so that the text is tangential to that circle. I could draw the rectangles which should contain the text, but when I try to set the text it comes up in some oblique angle
https://cad.onshape.com/documents/5935e8d7ef8157145f5f05f3/w/8743202fb7bcd97befb0ffba/e/068a024a549426b7b4e83622
I hope it is clear what I mean.
Thanks for your help
  • robert_scott_jr_robert_scott_jr_ Member Posts: 652 ✭✭✭
    Perhaps the feature script discussed in this post might be applicable. - Scotty
  • hansrudolfhansrudolf Member Posts: 54 ✭✭
    Many thanks Scotty, your answer hit the nail on the head. After some experimenting with the parameters in that script, I got a perfect result.
    This success begs the question: is there somewhere in Onshape a (searchable) library of all feature scripts? How should a user find a script that he might need?
    Kind regards,
    Hansrudolf
