Arranging text in a circular array
hansrudolf
Member Posts: 55 ✭✭
Again one of the problems where I found no solution. Not even the AI could help…
I'm trying to set numbers around a circle, so that the text is tangential to that circle. I could draw the rectangles which should contain the text, but when I try to set the text it comes up in some oblique angle
I hope it is clear what I mean.
Thanks for your help
Perhaps the feature script discussed in this post might be applicable. - Scotty
Many thanks Scotty, your answer hit the nail on the head. After some experimenting with the parameters in that script, I got a perfect result.
This success begs the question: is there somewhere in Onshape a (searchable) library of all feature scripts? How should a user find a script that he might need?
Kind regards,
Hansrudolf
Here is one resource. Have fun. Perusing the site is intriguing.
There is a search tool within a document
@hansrudolf You can also try fs.place. It's not heavily used but I keep posting it so that people will slowly start adding their FS there.
Well, that's great. I already have seen scripts which could be useful for me.
I just hope I remember all this - but the forum entries seem to stay forever.
Thank you all, and kind regards
Hansrudolf
