Dimension an Arc length in Drawing
davis_pearson
Member Posts: 2 ✭
in Drawings
Is it possible to dimension an arc length in a drawing? I can get the radius/diameter dimension, and the angle dimension just fine, but can't seem to figure out how to get the length. The number I'm looking for would be the same as the measure tool and selecting the arc. I could just measure it and add the dimension manually, but I'd love for it to be calculated in case I need to update the arc later
13
Still not sure how it is 2025 and a seemingly basic tool for accurately dimensioning drawings has not been implemented. Hoping this gets added very soon.
Feels like some smart person could do a feature script to allow it to be dimensioned in a sketch, then the sketch could be shown in the drawing,
The improvement request is here:
Go vote.
Well, 5/13/2025, and I need to show "a dynamic" arc length on a drawing.
as Stan Lee would say, "nuff said".
@NeilCooke
Dear Neil,
maybe you can enlighten us with this question.
In sketches it is posible to dimension the length of an arc.
But in drawings it is not.
How can we solve this issue?
Thanks for your response.
@c_büscher The development work for arc length dimensions is in progress for drawings. It won't be possible as you want until we deliver on that. Currently most users call this out manually with a note.
I'm throwing a comment in here - and a request for Arc Length dim for drawings please.
I can appreciate manually creating a call out with a note for the time being - with the disclaimer that its not robust and can cause issues downstream in manufacturing if design changes are made an it is not manually updated.
