Drawing different position in one view
Is it possible to have 2 different position view in the same view on the drawing?
  • martin_kopplowmartin_kopplow Member Posts: 1,279 PRO
    You mean like a box with the lid open and then with the lid closed on one drawing sheet? That is possible, just make the box configurable and then assign each config to one view.
    Showing them both together in one view is probably not possible without evil tricks. You could possibly insert a sketch showing the other position into a view.
  • S1monS1mon Member Posts: 4,043 PRO
    You can definitely show more than one named position on the same drawing (see improvement video below), but to do two in the same view I would probably create a separate dummy assembly which does it.
    a7a255375ce94d58e74a30fcdcc0ef2fd5cff33f.jpg?image_play_button_size=2x&image_crop_resized=960x540&image_play_button_rounded=1&image_play_button_color=00890be0
    Improvements to Onshape - June 27th, 2022 — Onshape
  • alan_scott349alan_scott349 Member Posts: 4
    @slope I was wondering the same thing about showing two positions in a single view. sounds like creating a dummy assembly or using configurations is the cleanest way to go. Would be great if Onshape eventually added a built-in option for “overlay” positions (like open/closed states) directly in drawings — it’d make design reviews much clearer.
