Grid Extrude Custom Feature
2»
  • m_h2m_h2 Member Posts: 2
    @EvanReese
    If have some Issues with your feature… I can't generate the grid on this sketch… could you helpt me?
    edited March 2025
    is the rectangle possibly smaller than 25mm? Try reducing the cell width. Beyond that I'd need to get into the document to check it out if you can share it.
  • william_knoblauchwilliam_knoblauch Member Posts: 21 ✭✭
    Hey Evan,
    I recently found an issue with your script when trying to make a grid that subtracts from a part. I'm getting these weird fillets at the border of the pattern.
    It doesn't seem to be a systemic problem. It just happens when inverting the grid with a border and corner radius. Here are the settings I'm using:
    I'm pretty sure it's just the fillet query for the edges of the boundary.
    if (!tolerantEquals(definition.cornerRadius, 0 * meter) && !isCircleHex && !isCicleSq)
                    const moreToFillet = qUnion([qNonCapEntity(id + "boundary", EntityType.EDGE), qCreatedBy(id + "boundaryBoolean", EntityType.EDGE)]);
                    opFillet(context, id + "fillet2", {
                                "entities" : moreToFillet,
                                "radius" : definition.cornerRadius
    Restricting the queried edges to follow the direction of the extrude works, but there are still some edges that fail. (That's why I added try{} because opFillet() seems to fail even if you just look at it wrong)
                    const moreToFillet = qUnion([qParallelEdges(qNonCapEntity(id + "boundary", EntityType.EDGE), direction), qParallelEdges(qCreatedBy(id + "boundaryBoolean", EntityType.EDGE), direction)]);
                    try {
    I made a copy of your document and added those qParallelEdges() functions, and it works pretty well when doing what I wanted. The fillets fail when making a new part with a boundary, but with the original query, the whole script fails anyway.
    Thanks for the awesome script!
    Thanks! I appreciate you troubleshooting. I'll put it on my (fairly long) list of things to do
  • vadeniuc_mihaivadeniuc_mihai Member Posts: 3
    Hello, how could I use this feature to make this type of irregular hexagons, with different height and width. Or is there another feature for this?
    I'm not actually sure these are different heights and widths or if that's just an illusion of this imange, but Grid Extrude can't vary the instances. You could check out my Attractor Pattern feature and see if it's closer to what you're after.
    https://youtu.be/UM52GOmcV58
