Trying to create a loft [NEWB]
benn_banksbenn_banks Member Posts: 20
Hey peeps,
Im just getting into Onshape and im unable to get a loft to work.
I have a circle sketch on one plane and a sketch on another plant thats a half circle.  When i select Loft and then the 2 faces, on face disappears and nothing else happens.
Also why cant separate sketches on different planes be oriented to each other? or why cant a sketch just be moved manually along an axis w or w/o a measure of delta
    edited November 2015
    .... im unable to get a loft to work.
    Are both sketches closed (meaning no gaps in the boundary)?
    A closed boundary results in the enclosed area going a shade of grey
    Also why cant separate sketches on different planes be oriented to each other? ....
    if you mean, the rotation angle of one sketch specified with respect to the other, then the answer, is that it can.
    Please be more specific about what you're trying to do.
    .... or why cant a sketch just be moved manually along an axis w or w/o a measure of delta .....
    again, it can, provided constraints (of which you may not be aware) do not prevent it.
    You can find out if that's the problem by clicking on "Show constraints", and then click on the icon of any undesired ones, and press the "Delete" key
    https://www.onshape.com/cad-blog/tech-tips-constraining-your-sketch
    If you need to move a group of sketch elements a specified distance, you need to use dimensions and constraints so that those elements will maintain their shape throughout the move, but in such a way that the move is not prevented (although the direction of the move needs to be dictated by the constraints). Then you can add a driving dimension parallel to that direction to a fixed point (like the origin), and edit that dimension by the required delta.  Construction geometry can be added to help with any of these steps.
    There are lots of easier ways to do this but they are situation specific. Once again you need to tell us exactly what you're trying to do.
    For point-1 here is one method as given below.
  • benn_banksbenn_banks Member Posts: 20
    Thanks andrew_troup!! ill look into the second and third points, i figured there would be a way, it just doesnt seem obvious to me. As for the lofting issue, yes they are both closed faces.
    @benn_banks for point-2 of moving the sketches along the axis as a work around you can use circular pattern and convert remaining entities as construction lines
    https://us.v-cdn.net/5022071/uploads/editor/9k/pa841tr26ro1.gif
    Similarly, you can use rectangular pattern if you want to move the sketch linearly.
    To give some context, i'm trying to loft from the smaller half circle to the separate circle sketch and it doesn't seem to be working as described. i'm sure i'm just missing something dumb but i don't know what that is.
    Oh and the separate circle sketch is what i was trying to move, away and up closer to the solid.
  • shanshanshanshan Member Posts: 147 ✭✭✭
    benn_banks,share your document as public please !
    I totally can share it, i made it public but do i send you the URL in my browser or is there another way?
    copy and paste the URL here, and then we can click and open it!
    111.PNG 12.1K
    i didnt mean how to add a link in the forum, i meant what link from my model do i share. Ill try this one first
    https://cad.onshape.com/documents/632ee27db0bc4c9ab2afff77/w/083f63b70850488e8ab2740e/e/b9c7442dffe844c3a99a04c1
    Im trying to make a modified version of this part
    hiding the solid made helped
    When I try to open that, I get a message "Failed to load document for workspace. Cannot open a document in the trash"
    Did you copy the URL from the current document address bar at the top? If so, have you thrown it out since?
    ..... the separate circle sketch is what i was trying to move, away and up closer to the solid.
    By "away and up closer" I'm guessing you want to shift BOTH the plane, AND the circle location on the plane?
    Planes can be edited by double clicking on the plane name in the feature list at left: change the dimension in the box "Offset distance"
    Circles can be moved across a sketch plane by editing the sketch (shortcut=double click, again) then dragging by the centre point if it's unconstrained, or editing dimensions if that's what's locating it.
