Trying to create a loft [NEWB]
in Drawings
Hey peeps,
Im just getting into Onshape and im unable to get a loft to work.
I have a circle sketch on one plane and a sketch on another plant thats a half circle. When i select Loft and then the 2 faces, on face disappears and nothing else happens.
Also why cant separate sketches on different planes be oriented to each other? or why cant a sketch just be moved manually along an axis w or w/o a measure of delta
andrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭
@benn_banks
I would hide the part so I can be sure of seeing and selecting the sketch for the smaller circle segment.
You can select faces of a solid when they are "positive space", but not when they are "negative space", as in this instance.
(I'm slipping into artists' terminology here, it 's not strictly or even approximately kosher for solid geometry)
HTH, if not, you could make your model public and post the URL here.5
A closed boundary results in the enclosed area going a shade of grey
if you mean, the rotation angle of one sketch specified with respect to the other, then the answer, is that it can.
Please be more specific about what you're trying to do.
again, it can, provided constraints (of which you may not be aware) do not prevent it.
You can find out if that's the problem by clicking on "Show constraints", and then click on the icon of any undesired ones, and press the "Delete" key
https://www.onshape.com/cad-blog/tech-tips-constraining-your-sketch
If you need to move a group of sketch elements a specified distance, you need to use dimensions and constraints so that those elements will maintain their shape throughout the move, but in such a way that the move is not prevented (although the direction of the move needs to be dictated by the constraints). Then you can add a driving dimension parallel to that direction to a fixed point (like the origin), and edit that dimension by the required delta. Construction geometry can be added to help with any of these steps.
There are lots of easier ways to do this but they are situation specific. Once again you need to tell us exactly what you're trying to do.
https://us.v-cdn.net/5022071/uploads/editor/9k/pa841tr26ro1.gif
Similarly, you can use rectangular pattern if you want to move the sketch linearly.
To give some context, i'm trying to loft from the smaller half circle to the separate circle sketch and it doesn't seem to be working as described. i'm sure i'm just missing something dumb but i don't know what that is.
Oh and the separate circle sketch is what i was trying to move, away and up closer to the solid.
https://cad.onshape.com/documents/632ee27db0bc4c9ab2afff77/w/083f63b70850488e8ab2740e/e/b9c7442dffe844c3a99a04c1
Did you copy the URL from the current document address bar at the top? If so, have you thrown it out since?
By "away and up closer" I'm guessing you want to shift BOTH the plane, AND the circle location on the plane?
Planes can be edited by double clicking on the plane name in the feature list at left: change the dimension in the box "Offset distance"
Circles can be moved across a sketch plane by editing the sketch (shortcut=double click, again) then dragging by the centre point if it's unconstrained, or editing dimensions if that's what's locating it.
