onshape cant export
I've been trying to export a STEP file from Onshape, but it doesn't download
  • MichaelPascoeMichaelPascoe Member Posts: 2,671 PRO
    edited November 25
    You probably have the "Store file in tab" selected. Make sure this is unchecked when exporting.
    We are currently investigating. Follow https://status.onshape.com/incidents/0f0v51phsl9t for updates.
    Jake Ramsley
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,032 PRO
    step files are not exporting for me right now.
  • robert_johnstonrobert_johnston Member Posts: 62 PRO
    PDF export not working too.
  • john_bass246john_bass246 Member Posts: 2
    I see that a fix has been implemented. Just to let you know, I am able to import a step file that I couldn't previously (a bolt from McMaster), but some files still get stuck in "Uploading" or "Translate" (a PCB from Adafruit).
  • tom_schaefertom_schaefer Member Posts: 4
    We can export STL's now but not STEP. The status states "A fix has been implemented and our team is monitoring.", however that's not completely accurate.
  • j_f857j_f857 Member Posts: 2
    I am also having trouble exporting files. I select export and I get the popup that tells me the file is being prepared and I will get a notification when the file is ready to export. Nothing happens after that. Waiting does nothing. I never get a notification nor a download.
    1. Tried many different formats,
    2. different parts within a files,
    3. and different projects with different combinations of parts and formats
    4. Also tried exporting to One drive instead of downloading.
    Getting a ton of these errors every couple of seconds now:
    Onshape encountered a problem with your last operation. If the problem persists, contact support. Support code a42a3390f25d820101451115.
  • hoang_namhoang_nam Member Posts: 2
    oh me too😥
