onshape cant export
bao_nguyen487
Member Posts: 2 ✭
I've been trying to export a STEP file from Onshape, but it doesn't download
2
You probably have the "Store file in tab" selected. Make sure this is unchecked when exporting.
We are currently investigating. Follow https://status.onshape.com/incidents/0f0v51phsl9t for updates.
step files are not exporting for me right now.
PDF export not working too.
I see that a fix has been implemented. Just to let you know, I am able to import a step file that I couldn't previously (a bolt from McMaster), but some files still get stuck in "Uploading" or "Translate" (a PCB from Adafruit).
We can export STL's now but not STEP. The status states "A fix has been implemented and our team is monitoring.", however that's not completely accurate.
I am also having trouble exporting files. I select export and I get the popup that tells me the file is being prepared and I will get a notification when the file is ready to export. Nothing happens after that. Waiting does nothing. I never get a notification nor a download.
Getting a ton of these errors every couple of seconds now:
Onshape encountered a problem with your last operation. If the problem persists, contact support. Support code a42a3390f25d820101451115.
oh me too😥
